Thread: 1rst build, time to do next step
First of all I want to say hello to everyone and thank you for sharing with their experience and knowledge!
After a year or so reading on CNC forums I decided that I have more knowledge about it than before and I think I'm ready to go to the next step.
But first of all I would like to hear from more experienced members than I about my CNC design and hardware, any input or criticism are more than welcome guys.
So there is a components which I decided to use in my build:
Whole machine will be from aluminum, plates (10, 20 and 25 mm thick) and profile 45x90
Ball screw for the X - RM 2005-RM 2010 ???, with fixed + fixed ends
Y - RM1605-RM1610 ???, same as X fixed ends
Z - RM1605
Hiwin profile rails, X-25mm, Y and Z 20mm
Nema 23 motors 320 oz-in 2.8 mH 3.5A, all axis
48V 12.5A power supply
Gecko G540 4 Axis stepper driver
Water-cooled spindle motor 2.2kw with a VFD
oh yes, I forgot to say that is cutting area is about 1220x845 mm
So that is all for now, Thanks again to all and good luck to everyone !
Excuse me for my bad English
Gytis
05-07-2013 #2
X isn't long enough to warrant a 20mm diameter screw, so use RM1610.
Gecko G540 is a waste of money - get something like this:
CNC Micro-Stepping 57 Stepper Motor Driver 2M542 2phase 4.2A Switch Controller | eBay
Or better, a higher voltage driver, like DQ860MA - cheap at AliExpress.com - Online Shopping for Electronics, Fashion, Home & Garden, Toys & Sports, Automobiles from China.
These motors are good and probably cheaper than what you specified.
25mm profile rails are completely over the top, so unless you've found some cheap ones on eBay I'd go for smaller rails - even 15mm would be fine for this size machine.
Your gantry could be made a lot stronger without using more material - flat plate is the worst cross section for the gantry since the forces are often in the direction where it is weakest. Box section would be better, or even better remove the gantry sides and have the Z-axis operating below the level of the X-rails.
05-07-2013 #3
Hello Jonathan, and Thank you for your reply !
well, you are right., I was thinking same as you., but when I got my first ball screw RM1605 1m long it was bent about 5 mm in the middle, so I can just imagine what will happen with 1.6m long screw
I can not argue with you about the drivers and motors, probably you are right .,Gecko G540 is a waste of money - get something like this
but : 1. I already have one G540
2. maybe I have spent to much my time on American forum before I found you guys in the UK (so there is reason why I have chosen these drivers and motors)
I'm not sure about 15mm rails, it seems to me that is too weak25mm profile rails are completely over the top
no, I don't like this design, I want to keep open table design and keep rails & ball screw from dust as much as I canor even better remove the gantry sides and have the Z-axis operating below the level of the X-rails.
And finally, this machine will be built not for hobby use, she has to be strong and durable
Gytis
06-07-2013 #4
Hi Gytis,
First don't listen to Jonathan the G540 is a great bit of kit for a small machine. There are cheaper but it's a quality unit with great back up and warranty from Gecko and worth the money.
BUT every thing else he's correct about.
15mm profiled rails will be plenty strong enough and carry far more load than you'll put on the machine.
The only issue with smaller profiled rails is the small bearing blocks can be a pain, esp with making the Z axis has the low height often means using spacer blocks to allow clearance for ballscrew etc. I find 20mm a much better size bearing and plenty on top of the job.
Your design will be substantially weaker than what Jons suggesting and if you want strong and durable then it doesn't get much better.
Has for keeping the screws protected then that's easy enough with a bit of thought regards covers etc. The high sides don't cause any issues in use for most work and actually help contain the cutting mess to the table area instead of slinging it all around the shop.
The advantages of the much increased strength and far better quality of finish on work combined with allowing higher feeds is well worth the sacrifice of bit of access when loading material. End of the day it's the quality and speed of cut that matters.
Both Jon and I have been there done/seen that route so believe me we speak from experience on this.!!Last edited by JAZZCNC; 06-07-2013 at 03:00 PM.
07-07-2013 #5
Hello JAZZ, and thanks for your input !
now I'm sitting and scratching my head ..,Your design will be substantially weaker than what Jons suggesting and if you want strong and durable then it doesn't get much better.
new design?, short as possible sides?, Z-axis below the level of the X-rails?, Hiwin rails 15-20mm?
Gytis
07-07-2013 #6
Don't despair thats par the course with first machine.!!. . . I had full head of hair before getting into CNC now I'm follicle challenged. . Lol
To be honest I may have jumped the gun slightly because I didn't ask what you intend to cut with this machine.?
If soft materials plastics,softwoods etc then the high sides won't be a problem. There's no disputing the high sides are weaker design than no sides design but they do work ok in soft stuff if rest of gantry is stiff enough.
That said sorry to say your gantry design is very weak and the single piece of plate for gantry is real bad idea. Also the Y axis ballscrew hanging down is just asking to get clobbered with rubbish.
Look around the forum you'll see pics of similar built high side machines with strong gantry's, I've posted pics of similar machines I've built that use profile which is strong design and can handle cutting upto light aluminium work.
10-07-2013 #7
There are two areas that look like they need strengthening on that design. The bed plate needs support otherwise it'll bounce and flex like nobody's business and you'll get a crap finish. Can you not just use the profile as the base and put profile laterally across under the bed plate to stiffen, seems like there's an awful lot of empty height under the bed plate?
The Y axis plate also looks like it needs a length of profile or two behind it otherwise it might also flex when cutting in the middle of it.
Hope this post doesn't sound negative, just a couple of observations :)
10-07-2013 #8Hello Neil,There are two areas that look like they need strengthening on that design. The bed plate needs support otherwise it'll bounce and flex like nobody's business and you'll get a crap finish.
I just forgot to mention that now I working on Z axis, and this table top sitting just to see what travel I need in the Z or how low bed has to be.
Sorry for confusing you
Gytis
11-07-2013 #9
Okay you want to build an all round Gantry router to cut up to aluminium. Lower your bed and re-enforce it as suggested though don't over do it too much (we DIY folks do tend to over build). I would strongly, strongly suggest putting the Y axis screw behind the gantry beam if at all possible. it reduces issues with swarf and makes lubricating it much, much easier.
Go looking through the build logs as I know there is some very good designs there. You don't have to use any of them but they do give a very good head start. Also I don't see allowances for cable paths; that is something you really want to think about now. later it will bite your back side and cause issues (I can think of a few members who can tell about the headaches of wiring gone wrong).
Jonathan is correct that at that length 1610 will do you well and you can always work with the pulleys to get the resolution you want.
Good luck and keep asking questions.
Jonathan, Gecko are good equipment and they stand behind their warranty as more then a few folks have proven. Yes, they are a bit costly but they are serious kit for some one wanting a business level ROI (return on Investment). Next you will be telling me my Leadshine AM882's are over kill. Horses for courses.
-Michael
PS Contrary to my long absence I have not died nor fallen off the face of the earth just been very very busy.Software SolidWorks 2024, Onshape, Aspire v9.5, Blender
CNC Machine: http://www.mycncuk.com/threads/3661-...Second-machine
3D printers both FDM/FFD and MSLA resin
CSWA &CSWA-AM certified
www.marino-customs.com
16-07-2013 #10this is what I really need nowGood luck
Thank you Michael
Step drill bits (where to get) ?
By Gytis in forum Marketplace DiscussionReplies: 10Last Post: 07-08-2013, 12:04 AM -
NEW MEMBER: First time build
By PAULRO in forum New Member IntroductionsReplies: 3Last Post: 22-02-2013, 01:37 PM -
OK, time to heed the advice of people on here and change build material
By deannos in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-12-2011, 11:29 AM -
Step 4 router
By John S in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 11-08-2009, 04:16 PM -
Step clamp
By Lee Roberts in forum Programmers CornerReplies: 0Last Post: 14-10-2008, 02:39 AM
