    If soft materials plastics,softwoods etc then the high sides won't be a problem
    you wouldn't believe me, but I was almost sure that I will be able to cut hardwood and do light aluminum work (now you can laugh of me)
    Ok., I think I know what you both trying to say for me..,
    so now in my head I have new CNC table plan ( I hope it will cut at least hardwood ).
    Version_2 will be here soon
    Thanks guys for the advice!
    Hello,
    quick update., the Version_2 is nearly done.
    now I thinking about X axis ball screw fitting,
    my very first idea was to put it between the aluminum profiles, but now I'm not sure or it good idea, I think distance is to big between rails and screw approx.150mm?
    what if I run it through the side plate support box?, right now there is few brackets., just one what I do not like, that the screw will be very few cm. above the table.
    But maybe I can fix on each side of the box some brush or seal to wipe the dust away from screw ?
    btw, what about design? Version_2 will be stronger then the first?
ID:	9231   Click image for larger version.
ID:	9232   Click image for larger version.
ID:	9233   Click image for larger version.
ID:	9234   Click image for larger version.
  1. Step drill bits (where to get) ?
    By Gytis in forum Marketplace Discussion
    Last Post: 07-08-2013, 12:04 AM
  2. NEW MEMBER: First time build
    By PAULRO in forum New Member Introductions
    Last Post: 22-02-2013, 01:37 PM
  3. OK, time to heed the advice of people on here and change build material
    By deannos in forum Gantry/Router Machines & Building
    Last Post: 12-12-2011, 11:29 AM
  4. Step 4 router
    By John S in forum Milling Machines, Builds & Conversions
    Last Post: 11-08-2009, 04:16 PM
  5. Step clamp
    By Lee Roberts in forum Programmers Corner
    Last Post: 14-10-2008, 02:39 AM
