Thread: 1rst build, time to do next step
20-07-2013 #12
Yes it does but:
A. its much harder to set up right
B. the speed increase factor isn't needed here - very roughly 2600rpm to 3900 rpm for a 16mm screw. Even with a 1605 screw the lower end is >10m/min, far more than you'll achieve in reality
C. It needs more complex machining of the ballscrew end
D. It costs more
By your own admission this is your first build so KISS IMHO :D
Step drill bits (where to get) ?
By Gytis in forum Marketplace DiscussionReplies: 10Last Post: 07-08-2013, 12:04 AM -
NEW MEMBER: First time build
By PAULRO in forum New Member IntroductionsReplies: 3Last Post: 22-02-2013, 01:37 PM -
OK, time to heed the advice of people on here and change build material
By deannos in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-12-2011, 11:29 AM -
Step 4 router
By John S in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 11-08-2009, 04:16 PM -
Step clamp
By Lee Roberts in forum Programmers CornerReplies: 0Last Post: 14-10-2008, 02:39 AM
