Thread: 1rst build, time to do next step
20-07-2013 #18
Could tell you Irving but then I'd have to kill you all to protect my self. .
Completely agree with Irving. Fine for industrial machines using servo's with high feed rates 25m/min+ and heavy loads but here the only difference you'll see is less cash in your wallet.!!
With DIY building you'll gain more performance by concentrating on build quality and careful alignment of screws/motors and linear rails than using Industry standards.
One thing wanted to point out which catches new builders out is to think carefully about bolt hole location and fastening of brackets etc.?
Often the obvious place to fasten something is completely the wrong place which makes assembly a right pain in the arse.
IE: You have the Y axis ball-nut bracket (thru slot) fastening from the front side of Z axis rear plate. Doing this means you have to remove front plate from Z axis to access those bolts or drill access holes in it.
You need this bracket to have some adjustment to make alignment with Y axis ball-nut easy and doing this from front and thru a hole will be a pain so would be much easier if it bolted from the rear into tapped holes in the Z axis rear plate.
It's simple things like this that make building and setup just that bit less painful.! . . . Unfortunately finding these things out often comes from building the first machine and at worst case scraping a few parts learning on first build.
Step drill bits (where to get) ?
By Gytis in forum Marketplace DiscussionReplies: 10Last Post: 07-08-2013, 12:04 AM -
NEW MEMBER: First time build
By PAULRO in forum New Member IntroductionsReplies: 3Last Post: 22-02-2013, 01:37 PM -
OK, time to heed the advice of people on here and change build material
By deannos in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-12-2011, 11:29 AM -
Step 4 router
By John S in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 11-08-2009, 04:16 PM -
Step clamp
By Lee Roberts in forum Programmers CornerReplies: 0Last Post: 14-10-2008, 02:39 AM
