  1. #19
    Could tell you Irving but then I'd have to kill you all to protect my self. .
    Fine for industrial machines using servo's with high feed rates 25m/min+ and heavy loads
    This will be my second CNC with these feed rates
    You need this bracket to have some adjustment to make alignment with Y axis ball-nut easy and doing this from front and thru a hole will be a pain so would be much easier if it bolted from the rear into tapped holes in the Z axis rear plate.
    You mean like this (see pics) , just drill a bigger hole in the bracket for adjustment ?
    Unfortunately finding these things out often comes from building the first machine and at worst case scraping a few parts learning on first build
    I understand this and I'm ready for this (to scrap few parts, especially with my tools)!
    Thank you guys
  1. Step drill bits (where to get) ?
    By Gytis in forum Marketplace Discussion
    Last Post: 07-08-2013, 12:04 AM
  2. NEW MEMBER: First time build
    By PAULRO in forum New Member Introductions
    Last Post: 22-02-2013, 01:37 PM
  3. OK, time to heed the advice of people on here and change build material
    By deannos in forum Gantry/Router Machines & Building
    Last Post: 12-12-2011, 11:29 AM
  4. Step 4 router
    By John S in forum Milling Machines, Builds & Conversions
    Last Post: 11-08-2009, 04:16 PM
  5. Step clamp
    By Lee Roberts in forum Programmers Corner
    Last Post: 14-10-2008, 02:39 AM
