Thread: motor gearing (cog) help please
Wouldn't use these gears on CNC machine without some form of mechanical fastening.
Would Either buy gears with key ways or have some machined into existing gears. Both Drilling/Taping and keyway cutting could be difficult has they may well be hardened gears.? try a file on them to check before attempting either.
If not then I'd simply drill/tap and use set screw along with Loctite.
06-07-2013 #2
I have a feeling they are hardened although not actually checked yet, any idea where I might be able to buy something off the shelf or is it going to be a case of having to get some made? They are probably imperial as the rest of the machine seems to be, guess that is because Gerber are an American Company.
Rack & Pinion Gearbox/Gearing
By andrewbond in forum Rack & Pinion SystemsReplies: 21Last Post: 12-09-2015, 09:10 AM -
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
By ba99297 in forum DIY Router Build LogsReplies: 12Last Post: 03-09-2013, 10:37 PM -
Hobbymat BFE65 Conversion - Gearing my Steppers?
By jamezwarner in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 06-09-2011, 06:08 PM
