Gents,
can I push a floating bearing against a shoulder (or a circlip) on a shaft and secure the bearing with a circlip or do I need some sort of lock nut to make sure it stays put all the time? with a circlip I guess I'd have around 0.1-0.2mm of 'slack', but I reckon that shouldn't matter as the shaft is already located by the locating bearing (angular contact double row) right? I'm going for an interference fit on the inner ring and H6 / loose fit on the housing to allow for movement.
Appreciate any info, cheers.
Regards,
dsc.
25-06-2013 #2
A circlip would be fine, it is to stop it wondering really. Mine just rests in place and never had an issue as the bearing is locked in place withinh it's housing.
25-06-2013 #3
28-06-2013 #4
On mine the outside of the bearing is fixed, the inside floats. no real right or wrong way. It just stops the screw from whipping about.
28-06-2013 #5
Indeed if it's only used to stop the whipping, if it's supposed to carry any load, then it depends where the load is attached and that affects how the inside / outside rings should be fixed (and what fit should be used).
Regards,
dsc.
28-06-2013 #6
The load is on the other end, the screw is turned down at the floating end with a gap between the thread of the screw and bearing. The commercial ones off ebay and the likes have a circlip holding the bearing onto the screw. In this situation the bearing should be a loose fit into it's mounting.
Mach3 and CNC3040 incorrect zero location
By RoyT in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 30-10-2013, 03:29 AM -
Pulley grub screw location
By booski in forum Belt Drive, Pulleys & TimingReplies: 10Last Post: 30-07-2013, 12:56 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Location of machine problem
By Eugene in forum Computer SoftwareReplies: 2Last Post: 27-01-2011, 07:00 AM
