10-07-2013 #11
Is it critical for the value of the zener diode as I can only get my hands on a 2.7v jobbie today
10-07-2013 #12
No, but a higher voltage zener will mean the potentiometer will be working a bit harder.
10-07-2013 #13
Not really, your output voltage will be 0 - 2.7v rather than 0 - 1.5 so trimming it will be slightly more fiddly.
I'd set it to zero and connect it up and then bring it up to the voltage you want - this will negate any effects due to the load the ECU puts on the potential divider.
10-07-2013 #14
Ahh ok. Well thanks for your help guys I'll try and slap something together today. Cheers :)
10-07-2013 #15
Can I ask what car this is for?
10-07-2013 #16
It's for a Toyota Corolla Compressor
10-07-2013 #17
Well works like a charm on the meter so now to plumb it in.
29-12-2022 #18
Hello Mc I have the same situation as AdCNC Had to you still have that schematic you drew up for him if I could get a copy it would same me so much time thank you
31-12-2022 #19
control signals to draw a circle
By lakmalp in forum Machine Control SoftwareReplies: 3Last Post: 16-06-2013, 05:52 PM
