Gents,
recently I acquired a set of telescoping gauges and small bore gauges. Both sets lightly used, so I thought I'd give them a clean and oiled them up nicely. Got some Singer machine oil which I've seen recommended on a few machining forums for lubing mics etc., but I'm not 100% sure what to use for the overall clean. The tools are not overly dirty, mostly just some old grease here and there, some gummed up grease inside the tele gauges and the romantic aroma of musk / mold on the whole lot (binned the pouches, but the smells sticks to the handles somehow). Any suggestions? I'm guessing I'll disassemble the whole lot and soak overnight, then dry, lube and re-assemble.
Regards,
dsc.
11-07-2013 #2
WD40. Marvellous stuff and smells lovely.
11-07-2013 #3
I was under the impression that WD40 leaves a slightly sticky film and is not recommended. I was leaning more towards spirits, isopropyl alcohol etc.
Regards,
dsc.
Help needed with understanding accuracy in measuring tools. I want to go straight :-)
By Boyan Silyavski in forum Tool & Tooling TechnologyReplies: 25Last Post: 01-10-2013, 05:17 PM -
Heavy Duty Extension Spring
By Stevetechguy in forum Manufacturer NewsReplies: 0Last Post: 17-10-2012, 04:45 PM -
Spring loaded drag engraver
By Sharx in forum Tool & Tooling TechnologyReplies: 1Last Post: 16-02-2011, 11:10 PM -
Measuring Spindle Runout
By Lee Roberts in forum Spindles & Drive MotorsReplies: 0Last Post: 18-10-2008, 11:47 PM
