Yeah, pretty much. I just tape a piece of wire to the board with a bit of tape and then a croc clip to my spindle. The software then probes the height of the board.
22-07-2013 #2
Ralph Waldo Emerson
22-07-2013 #3
Well, I have a simple parallel port chinese TB6560 controller and I use one of the input pins on the controller setup in LinuxCNC as a probe. There are 5 input pins on my controller and 1 common, so with a lead connected to the common and another connected to the input.
With the probe attached to the tool, the Z axis comes down and when the tool makes contact with the board, it measures the height and adjusts the rest of the g-code to suit the board at that point.
22-07-2013 #4
22-07-2013 #5
Haha, yeah, must remember to remove the probe.
Fortunately, my DIY spindle motor has pillars holding the motor and so is directly connected to the tool so I haven't got to worry about removing the croc clip.
The autoleveller software if I remember correctly allows you to set the probing speed which default is 100mm/m I think so it's very slow and the machine reacts quick enough that it doesn't damage the board. Similarly, I set the retract height to 1mm so that it retracts quickly and moves to the next point quicker. Could even set it to much less than that really for quick probing.
22-07-2013 #6
Ralph Waldo Emerson
engineers square - recommendations
By dsc in forum Marketplace DiscussionReplies: 0Last Post: 09-06-2013, 08:13 PM -
WANTED: 3-Axis Mill recommendations
By TomB in forum Items WantedReplies: 0Last Post: 05-10-2012, 10:06 AM -
CNC Lathe recommendations?
By UltraMagnus in forum Lathes, Lathe Rebuilding & ConversionsReplies: 0Last Post: 07-09-2011, 08:51 PM -
Looking for Lathe Cutting Tools
By Zeeshan in forum Tool & Tooling TechnologyReplies: 2Last Post: 06-09-2011, 09:50 AM -
UK Supplier of Cutting tools
By Ccrewz in forum Tool & Tooling TechnologyReplies: 4Last Post: 03-02-2010, 11:32 AM
