    So back to my original question, my new machine running 4.2a 50v steppers and a 3kw spindle I'll be drawing somewhere in the range of 5-6 thousand watts.
    even a basic consumer unit will cover those needs easily.
    what do you mean by having an isolator in the house? do you mean one line straight from the house's RCD to its own MCB in then going to the shed?
    I'm probably not going to attempt it and see if my family are owed any favors, I just want to learn a bit more :)
    Quote Originally Posted by jcb121 View Post
    .. 4.2a 50v steppers and a 3kw spindle I'll be drawing somewhere in the range of 5-6 thousand watts.......I just want to learn a bit more :)
    4.2A @ 50V is 210Watts
    X 3 = 630w
    It`s 630W at 50V or 250V , for calculation and allowing power supply losses call it a 1 kilowatt plus your 3 Kw spindle sounds like your allowing 1-2kW for lighting...
    if you want to learn a bit more , read the link previously provided.
    BUT if you are unsure about calculating loads , exporting power outdoors is considerably more involved and will be best left to someone comfortable with calculating things like earth impedance and disconnect time.
  1. Best type of shed.
    By Philly in forum General Discussion
    Last Post: 03-11-2018, 08:17 PM
  2. Garage CNC - A gantry style machine design
    By fandango in forum Gantry/Router Machines & Building
    Last Post: 21-03-2014, 01:38 AM
  3. How I almost set fire to my garage...
    By cncJim in forum General Discussion
    Last Post: 07-02-2014, 11:51 AM
  4. Community Shed
    By Musht in forum General Discussion
    Last Post: 06-10-2013, 12:15 PM
  5. My garage
    By wilfy in forum Workshop & Equipment
    Last Post: 18-02-2013, 06:40 PM
