    Really Depends on what amps your pulling but working from an extension isn't good idea in any case.!! Your just asking to burn the place down and by that I mean the house not the Shed.
    On top of this Insurance will just laugh and give you the finger when found using extension or any kind of dodgy wiring.!
    Really you want it on it's own circuit with it's own fuse and using appropriate sized wire for the amount of draw. Anything less is just not worth the risk IMO.
    okey dokey, I'll get in touch with a professional
    I think that you will find that you will need to have an isolator in the house and a consumer unit in the shed and the cable will need protecting with an rcd I would use wire armoured cable between to two. ...Clive
    The lights will blink if they are on the same circuit, lighting is usually on a separate circuit so as not to worry you.
  1. Best type of shed.
    By Philly in forum General Discussion
    Last Post: 03-11-2018, 08:17 PM
  2. Garage CNC - A gantry style machine design
    By fandango in forum Gantry/Router Machines & Building
    Last Post: 21-03-2014, 01:38 AM
  3. How I almost set fire to my garage...
    By cncJim in forum General Discussion
    Last Post: 07-02-2014, 11:51 AM
  4. Community Shed
    By Musht in forum General Discussion
    Last Post: 06-10-2013, 12:15 PM
  5. My garage
    By wilfy in forum Workshop & Equipment
    Last Post: 18-02-2013, 06:40 PM
