Thread: Capacitor questions
I think that the reason they use the polyester type is to get a more uniform part.
The high voltage is just really an indication of the capacitors construction type in that the polyester has a high breakdown voltage.
You will have to trawl the catalogues to find the smallest physical size for that type of capacitor, if memory serves most of that type will be on the larger side!
peter
Try these quite small http://www.futurlec.com/Capacitors/C1000UPF.shtmlLast edited by ptjw7uk; 17-07-2013 at 08:26 AM. Reason: add link
17-07-2013 #2
Thanks for the link I actually use this part on another project never thought of using it on this :) doh !
Ralph Waldo Emerson
17-07-2013 #3
Slightly off topic (curiousity has got the better of me)...the schematic you posted shows a bipolar supply, so why are they using a virtual ground IC in the power supply section?
There are parts of your schematic cutoff from view so maybe that the bit of the puzzle I'm missing!Last edited by HankMcSpank; 17-07-2013 at 06:30 PM.
17-07-2013 #4
I work in one of the UKs best HiFi R&D departments so I could answer this one!
People think higher voltage elec. caps sound better as they are meant to be more linear with change in voltage on their plates. Film is the best to use in this application. Use a large ECHU capacitor perhaps use two 470nF in parallel rated at 10V or 16V is absolutely fine.
17-07-2013 #5
Thats awsome thanks for the advice Boscoe :) Do you think I can convert this to SMD ? As your the first real sound expert I've talked to. I've spent months trying to learn this stuff but i'm just scratching the surface, what i really need is a good CMoy design that I can use SMD parts on so I can get it small enough and cheap enough to shoehorn into a tabbaco tin with 2 x 9v batteries. Any ideas ? :) I wont lie, I intend to sell them, I need the money lol
Ralph Waldo Emerson
17-07-2013 #6
Sure it's quite easy to fit it all in with two 9V batteries. It will be a lot easier to do it all SMD just use the filters on Farnell to find your parts if the existing ones don't have an SM equivalent. But I don't understand in your first post why you would use two 9V in series then try and split them into two 9V rails again? If your worried about DC offest don't be - your op-amps will keep the output voltage to what you want irrespective of the rails (to a point). You can also use voltage regulators instead however you will loose precious voltage. Look at this guys amp he made, he uses the same technique as I mention earlier and the THD is not measurable.
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's - diyAudio
17-07-2013 #7
Post deleted - I made an error!
17-07-2013 #8
17-07-2013 #9
actually, no I'm still a little puzzled.
The schem shows two 9V batteries in series (connected back to back) then uses a rail splitter to provide a virtual ground (the mid point of the battery voltage) ....I'm curious why bother, why not just use signal ground which will always be pretty close to mid voltage anyway (yeah, sure the batteries might not fade with the same 'profile' but there won't be much in it to warrant the extra expense & component count of the virtual ground IC)
Edit: Actually the schem just shows a single 18V single battery! (but I'm assuming that will be implemented by 2 x 9V batteries?)Last edited by HankMcSpank; 17-07-2013 at 07:59 PM.
17-07-2013 #10
Oh yes if you want to make an ultimate headphone amplifier use an LME49600 driven with a LME49990 with the 49600 in the 49990 feedback loop. Very simple similar to the one you post just much better.
few questions.
By jcb121 in forum General DiscussionReplies: 5Last Post: 03-06-2012, 08:20 PM -
motor start capacitor
By Scott in forum General ElectronicsReplies: 12Last Post: 11-02-2012, 04:56 PM -
NEW MEMBER: Hi all just a few questions!
By dubchip in forum New Member IntroductionsReplies: 17Last Post: 02-12-2011, 10:47 PM -
By dubchip in forum New Member IntroductionsReplies: 3Last Post: 10-11-2011, 03:40 PM -
New in CNC and I have some questions
By demestav in forum General DiscussionReplies: 0Last Post: 14-09-2011, 12:19 PM
