Thread: BK12 end float?
That can't be right. The 7000 series bearings are not designed for that much misalignment.
http://www.skf.com/group/products/be...ent/index.html
19-07-2013 #2
I agree. It doesn't seem right that we have to misalign the bearing to prevent end float. Are these just crappy bearings or am I being thick?
19-07-2013 #3
19-07-2013 #4
Haven't checked squareness of the bore/seat. Will check that tonight. Seats should be pretty clean as I stripped the blocks, cleaned them and greased the bearings.
Could I be OVER tightening the nut? I'm basically putting a piece of copper tube over the ballscrew shaft end, holding with a pair of pliers and tightening the nut until the pliers slip. Could this have damaged the bearings??
20-07-2013 #5
Problem solved. Couldn't get any preload with the bearings back to back so fitted a 0.2mm shim washer between the bearings to separate the outer races. I was then able to preload the bearings which worked out at finger tight plus about 1/4 of a turn of the lock nut. End float is now less than 0.01mm. Every day day is school day!
20-07-2013 #6
glad to hear that you sorted it out !
WANTED: BK12 Bearing Block Wanted - 1 off
By EddyCurrent in forum Items WantedReplies: 7Last Post: 11-03-2017, 08:52 PM -
BK12 Hole Spacing Dimensions On Top
By Hobgoblin in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 21-09-2012, 10:31 PM -
BK12 & BF12 bearings
By mlmSolutions in forum Lead Screws, Nuts & SupportsReplies: 0Last Post: 04-01-2011, 11:16 AM
