Thread: BK12 end float?
20-07-2013 #13
Problem solved. Couldn't get any preload with the bearings back to back so fitted a 0.2mm shim washer between the bearings to separate the outer races. I was then able to preload the bearings which worked out at finger tight plus about 1/4 of a turn of the lock nut. End float is now less than 0.01mm. Every day day is school day!
WANTED: BK12 Bearing Block Wanted - 1 off
By EddyCurrent in forum Items WantedReplies: 7Last Post: 11-03-2017, 08:52 PM -
BK12 Hole Spacing Dimensions On Top
By Hobgoblin in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 21-09-2012, 10:31 PM -
BK12 & BF12 bearings
By mlmSolutions in forum Lead Screws, Nuts & SupportsReplies: 0Last Post: 04-01-2011, 11:16 AM
