Thread: come on at least have a look
24-07-2013 #1
lower wide mounting points 150mm
centre hole 65mm
to take m6 socket caps
mill two from 1/2 inch thick alloy
how much please with post?
i can send you it dxfLast edited by nobby; 24-07-2013 at 11:59 PM.
25-07-2013 #2
ok t slot is 150mm on centres
I have the slot tab nuts, they are m6 - the bolt length doesn't matter as I shalll cut them
the socket cap head is 10mm wide
the motor is really light weight
is this how you would like the dxf?
anyways, the other idea of the flat mount is a foolish idea, as it involves spot facing? or milling the mount down,
I would rather two thin ones as it will look tidier, be less heavyand hold the thing better, plus in the future if i buy a 65mm 1.5kw motor and vhf, I can simply fling it in..........................
i do not know how I can attatch a dxf to this thread, - is it possible?Last edited by nobby; 25-07-2013 at 11:22 AM.
25-07-2013 #3
Flat plate would still work as the original mount would have machined faces on the bottom.
Check your pm.
02-08-2013 #4
this now taken care of thanks
08-08-2013 #5
thanks
09-08-2013 #6
Looks nice
09-08-2013 #7
09-08-2013 #8
Your very welcome. Im glad your happy with them.
