    Lives in East Lothian, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Do asc deliver nationally?
    Quote Originally Posted by deisel View Post
    agreed its hardly worth mentioning asc is cheaper unless your buying 500 notes to a grands worth of plate a time
    otherwise its a bag of chips and a spud fritter between em,and you still have the too and throw lark in email then the phone call with the card details.
    My last order with ASC was £174 with VAT total. Here are the first two lines:
    Put the same sizes in the aluminium warehouse site and it's £8.39 more, plus delivery at £12.49 so that's £20.88 saved. I'm happy to make a 5-10 minute phone call to save 20 quid!
    I don't think they deliver nationally as it just arrives on one of their company flat trucks. Still it might be worth asking if you're ordering a reasonable amount?
    i guess its swings and roundabouts then jonathan,my last order from them was a little over 100 quid for 20mm plate and by my reckoning and looking on the AW Site id saved about £1.95p lol wasnt worth it.
    ive used both companys a bit now and i will say in asc,s favour i only bother with the eco cast but where asc will have the courtesy to ring or mail and say look we have your plate ready to send but its damaged or marked on one side do you want us to send it?? AW just send it then ignore you when you winge about it.
    Yes, definitely. ASC seem to be more expensive for small sizes of aluminium round bar, but they've always been cheaper for me with 6082 aluminium plate. I've not ordered any tooling plate/eco cast from them so no idea what the difference is...
    Also, when they didn't have enough of something I wanted in stock they sent what they had then the rest in a couple of days, which I thought was good service.
  5. #15
    take back everything i said back about AW
    All has arrived. perfect condition.
  6. #16
    Asc wouldn't deliver to me when I asked them about delivery but that was quite a while ago so may have changed, being in scotland probably didn't help either as some people seem to think that non of Scotland is covered by mainland UK.
    Jonathan if you are using ASC quite a bit then you will probably have a trade account which could easily make the prices they charge you lower than anyone who is contacting them for the first time especially if they don't mention it is trade.
  7. #17
    Quote Originally Posted by martin54 View Post
    I don't have a trade account - I've ordered from there about 4 times in the past year, so not much really.
  8. #18
    I will post my question here as it relates to "aluminium warehouse"
    how accurate they doing cuts ?
    let's say that I need 200x200mm aluminum plate., they declared that "Cutting Tolerance: + 2.0mm / - Nil", it will be very complicated to get rid of extra 1 or 2mm on table saw or chop saw I thing?.
    Maybe it will be better to make orders on over sized plates?, and after cut to size what I need?
    Quote Originally Posted by Gytis View Post
    Better buying oversize then cutting. Ali plate cuts easily on a table saw with decent blade, I cut all my plate to rough size on table saw in one pass 20mm or more.!
  10. #20
    Plus I think they use a plasma cutter on the plate as the edges look melted and nasty.
    Ralph Waldo Emerson
  1. angular contact bearings - back to back, further apart
    By dsc in forum Linear & Rotary Motion
    Last Post: 05-01-2014, 10:59 PM
  2. wobble / wiggle on ballscrew double row angular contact bearing
    By dsc in forum Lead Screws, Nuts & Supports
    Last Post: 14-12-2013, 08:35 PM
  3. Aluminium passivation - for aluminium to be used outside
    By CHudson in forum Metal Finishing Techniques
    Last Post: 06-04-2011, 09:18 PM
  4. Ballscrew machining details
    By HiltonSteve in forum Lead Screws, Nuts & Supports
    Last Post: 24-07-2009, 04:01 PM
  5. NEW MEMBER: First contact
    By subtractive in forum New Member Introductions
    Last Post: 26-04-2009, 09:03 AM
