17-08-2013 #1
The more I play about with my CNC, the more I find I need a lathe to mill round or square solid bar for small projects.
My question is, when you buy a mini lathe such as the "Metal Worker Super C3 Mini-Lathe " or simular, do you get everything you need to ; as an example = milling down a 40mmx100mm round solid bar of mild steel to 35mmx100mm, then cutting a round pocket in the center at one end ?
Or are there hundreds of pounds to be spent for bigger jaws and different cutters etc before you can start to do such things ?
I have never owned one, so I do not have any exp with this.Last edited by dudz; 17-08-2013 at 05:50 PM.
Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
17-08-2013 #2
Title is supposed to read 350 to 500W !!
17-08-2013 #3
Hi dudz
Just had a quick look @ that and you appear to get a 3 Jaw Chuck as standard, for turning(not milling) square stock you will require the optional extra of the 80mm 4 Jaw Chuck which should possibly be able to grip 75mm stock, then you will need cutting tools to put in the toolpostLast edited by mekanik; 17-08-2013 at 06:11 PM.
The Following User Says Thank You to mekanik For This Useful Post:
17-08-2013 #4Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
17-08-2013 #5
You taking the Pi** M8
17-08-2013 #6
Uuuhh No. I simply do not have any idea !
I know there are different cutting tools, but I have absolutely no idea other than that.
If I was Taking the P**** I would come round your house and do it.Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
17-08-2013 #7
Nothing wrong with that question.??
DudZ for inside turning you need a Boring bar and for general outside or face turning then you just need standard tooling which comes in few forms.
Have a look on this page and you'll see sets cheap enough to get you going,Lathe Tools - Arc Euro Trade
When you get more into it you'll probably buy a few of the indexable tools. Look for indexable tooling and you'll see different forms and cutting angle's etc.Last edited by JAZZCNC; 17-08-2013 at 06:47 PM.
17-08-2013 #8
Great... Will do thx.
Just suming up wether it is more practicle to pay someone else to do the turning or set myself up. So gathering all the info I can.Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
17-08-2013 #9
17-08-2013 #10
Nice one jazz, had a change of heart & went to the same spot as you.Lathe Tools - Arc Euro Trade
SOLD: Various small CNC machines - ISEL/Unimatic
By badgerman in forum Items For SaleReplies: 14Last Post: 22-01-2020, 09:58 PM -
RFQ: Small sized Parts need making, small batches
By Ptee in forum Projects, Jobs & RequestsReplies: 3Last Post: 17-01-2014, 06:07 PM -
eBay: large amount of machines on e bay lathes mill plus other stuff
By Dellboy in forum Items On eBay UKReplies: 0Last Post: 17-06-2012, 09:35 AM -
WANTED: Wanted: Small Metal Work Milling Machine
By 07trb in forum Items WantedReplies: 0Last Post: 04-03-2011, 06:58 PM -
Lathes
By Web Goblin in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 18-02-2011, 10:32 AM
