    The adjustable ones are only listed in imperial sizes though.
    That's gotta be a joke yes ?
    Like the adjustable spanner marked out in inches one side and mm the other ?
    ARC's reamers are far cheaper, Tracy wants £12 for a 3/8" reamer, ARC wants £5.70
    Tracy only do metric as a set.
    John S -
    Yes ARC do a good service but for the record Tracy does Metric here :-http://www.tracytools.com/metric-reamers
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 375 times, giving thanks to others 9 times.
    I could of maybe worded that better, but I'm sure you know what I meant.
    I normally use ARC, but Tracy is handy for the more oddball stuff that ARC doesn't do, like the adjustable reamers I got last week for a bit head stock tweaking.
    That's all fairly reasonable. Not seen a 1/8 adjustable reamer yet but tempted with the 10mm.
    What would be preferred though, interference fit or snug fit with grub screws?
    And any more info on balancing with a scope?
    My alu tube turns up soon so I can start building the spindle and once its done, ill get some pulleys.
    I assume when turning shop bought pulleys its better to chuck up by the boss and not flanges?
    Quote Originally Posted by booski View Post
    Something like this:
    Balancing Tool
    Or you could use accelerometers...
    Never hold them by the flanges - they're only pressed on and not very strong. Hold the pulley by the boss and it's sensible to check with an indicator that it's on center.
  1. Mach3 and CNC3040 incorrect zero location
    By RoyT in forum Artsoft Mach (3 & 4)
    Last Post: 30-10-2013, 03:29 AM
  2. non-locating / floating bearing - shaft location
    By dsc in forum Linear & Rotary Motion
    Last Post: 28-06-2013, 10:07 PM
  3. pulley ratios on 3 pulley axis
    By Swarfing in forum Belt Drive, Pulleys & Timing
    Last Post: 21-07-2011, 12:43 AM
  4. Location of machine problem
    By Eugene in forum Computer Software
    Last Post: 27-01-2011, 07:00 AM
  5. WANTED: UNC grub screw supplier?
    By m_c in forum Items Wanted
    Last Post: 01-11-2008, 01:51 AM
