Thread: Stepping down from 5v to 3-4.5v
Don't forget to wire it the right way round else your laser won't turn on! The diode casing has a white line at one end, this end needs to be more negative than the other (i.e. points to the -ve end of the supply) for current to flow.
Bill's solution is the simplest and easiest to get a 0.7v drop at up to 1A (for an 1N4001 diode, although any of the 1N400x range will do). If you need more than 1A then 1N5059 series is good for 2A and 1N5624 series for 3A.
Stepping Motors & Drivers
By irving2008 in forum Stepper & Servo MotorsReplies: 3Last Post: 28-04-2015, 09:37 PM -
Multi stepping
By ptjw7uk in forum General DiscussionReplies: 8Last Post: 23-07-2009, 03:19 PM -
X axis not stepping
By m.marino in forum Marchant Dice MachinesReplies: 14Last Post: 21-04-2009, 08:37 AM -
Wow, stepping 13"/second
By Robin Hewitt in forum Machine DiscussionReplies: 2Last Post: 24-11-2008, 11:52 PM
