Thread: Gunna Bin The Lot GRR
Well that just sucks grrrrrrrrr more money, 'er indoors is gunna neck me. I bought the PSU so I didn't have to hack at the flakey YooCNC controller, looks like I'll be buying another one (PSU) and handing the lot to my son-in-law's cousin who fits alarms/security systems for a living for final wiring then dick around with getting it all to work with Mach.
IMO sellers need to mention these sorts of things in their listings, you can then buy all you need at once. Actually I'm pissed off enough now to email them and stick it up 'em sideways!!
Thanks for the info - if you happen to come across a decent wiring diagram I'd appreciate it, I'm pretty sure I've got the bob/steppers right but would like to double check.Cheers
Carl
Cardiff City Supporter ~ Real Sporting de Gijon Supporter ~ Vintage Synthesizer Collector
La gente dice que tu vida esta planeado, me gustaría encontrarse con el jefe de planificacion para que yo pudiera darle un punetazo en la cara!
30-07-2013 #2
do you need a power supply for the spindle? what voltage is it? It is quite possible that it isn't 24v, sorry I know absolutely nothing about these chinese machines.
30-07-2013 #3
I did send the seller an email a while back asking if I needed a PSU or how to wire the spindle up to that M542/bob setup and their response was 'sorry we don't know of spindles'. That's the only problem with buying off eBay, 90% of the sellers are just resellers with no idea and when you put them and people like me who are totally new to all this it gets to be a major headache!!
Just on the spindle proper, if memory serves, it's connected to the spindle/power control board and the only power in says 36v and 18v with a 24v connection out to the YooCNC - stuffed if I know to be honest.Cheers
Carl
02-08-2013 #4
If your still going to be using the yoocnc spindle control board , dont think it has a seperate supply , will check on mine, wouldn`t wire it through an external relay, not very robust drive ;-)
02-08-2013 #5
Ok I'll take an educated guess and say the 36V is for the spindle controller. So really answer to your problem is simple.? Replace the 24V PSU with 36V PSU and run them all from the same PSU.!!
Really you dropped a bollock buying the 24V supply anyway because the drives can handle upto 50Vdc and the motors will handle more than 24V, they will easily take 36v. The higher voltage will give more speed and torque so your Win win.
If the spindle board has run or start/stop signal pin then run this thru the Relay on the BOB and back to the board like Tenson says.
The BOB relay output is controlled thru M commands in the Gcode so it turns spindle on/off. If not then has last resort you could run the Spindle board power thru relay but if like MushT says it's flaky then it's risk you take.! . . . This is what the picture on advert going to spindle is badly depicting.!!
The spindle board will most likely have 0-10v connections which use the Step/dir pins to control speed/direction which you then take from spare output like A axis.
02-08-2013 #6
If its the original Yoocnc driver board for the 200W spindle on the 3040, it takes 220AC as marked on the board, it has a transformer mounted on board , think spindle, stripped down internals of s/h servo, is actually 90V.
If its something different , post a picture..
