  1. Also, if you're following that design..... don't... the single central screw for the X-axis will cause you hours of pain if you plan to cut anything stronger than cheese at the full width of the Y axis. Plan and budget for two screws and either 2 drives & motors or a single motor and pulley system unless you make the x-axis bearings really long to counteract racking. Go re-read some of the build logs, its been discussed in depth many times. If you're investing in a serious machine, best to get it right at the outset!
  1. Replies: 0
    Last Post: 04-12-2011, 03:23 PM
  2. FOR SALE: 25mm Linear Slide bearings
    By D-man in forum Items For Sale
    Last Post: 28-11-2010, 05:14 PM
  3. Calculating forces on linear bearings ...
    By Jonathan in forum Rails, Guideways & Bearings
    Last Post: 24-11-2010, 02:26 AM
  4. Anybody used these linear bearings before?
    By pjl83 in forum Rails, Guideways & Bearings
    Last Post: 08-06-2010, 12:42 PM
  5. Play in linear bearings
    By leadinglights in forum Rails, Guideways & Bearings
    Last Post: 01-05-2010, 05:01 PM
