Thread: DIY Linear Bearings
05-08-2013 #18
Not has much work has you may think, profile still has to be drilled, tapped etc and it's not always easy has folks think it's shitty stuff to drill and even worse to Tap good threads into.!
The best way is to use 15mm HTD timing belt and pulleys running around 2 idle bearings to central motor.
Your local bearing company may be the best place to ask, I use lots belts & pulleys and this what I find cheapest. . . . But failing that then there's likes of Bearing boys etc on-line. If you look around the forum others have posted links to places they've bought.
FOR SALE: ballscrews, supported linear rails, linear bearings, complete kit. for sale
By cutter in forum Items For SaleReplies: 0Last Post: 04-12-2011, 03:23 PM -
FOR SALE: 25mm Linear Slide bearings
By D-man in forum Items For SaleReplies: 4Last Post: 28-11-2010, 05:14 PM -
Calculating forces on linear bearings ...
By Jonathan in forum Rails, Guideways & BearingsReplies: 7Last Post: 24-11-2010, 02:26 AM -
Anybody used these linear bearings before?
By pjl83 in forum Rails, Guideways & BearingsReplies: 9Last Post: 08-06-2010, 12:42 PM -
Play in linear bearings
By leadinglights in forum Rails, Guideways & BearingsReplies: 17Last Post: 01-05-2010, 05:01 PM
