    Quote Originally Posted by CraftyGeek View Post
    Any thoughts or input would be greatly appreciated.
    I'll give you Input.!! . . .Don't bother messing around with making your own rails it's false economy.!
    In the early days I use to see this time and time again and it always ended up going the same way.?
    They would work for a fews weeks then become baggy and trouble some. Constantly sticking and stalling motors, crap building up on rails and jamming bearings etc etc etc with same result for everyone.!! They become frustrated with chasing problems and either scrapped the machine or changed rails for real thing.
    Over the last few years, which wasn't the case back then, supported linear round rail has become so cheap it's just not worth the hassle of not buying them.
    SO do your self a favour and buy supported linear round rail to start with you'll only end up doing so any way and the machine will perform twice better, give trouble free use from the get-go and last for years.
  2. Ok, i'll be honest - I haven't looked at supported rails or the cost of the bearings for them. I remember them being extremely pricey when I looked last time round...can you point me towards a reliable source of these said 'cheap' supported rails? so I can look at the cost involved vs what i'm looking at currently.
    You won't go wrong with this seller (known as Chai). Most of us use him as he's cheap and will machine ballscrews to whatever you want for next to nothing.
    linearmotionbearings2008 | eBay
    Chai is the one I use and bought many £1000's of stuff from him so know he's good guy to deal with but there are many on Ebay who sell them and could be slightly cheaper.? . . .They are all pretty much the same rails and probably come out the same factory.!
    Forgot to say I converted a mainly wood use machine that used Cncrouter-parts bearings and rail because the guy got so pissed off with having to cleaning the rails!! . . And that was after much messing about with wipers etc. . . . (Don't ask I've already gave them away. . Lol)
  5. Ok - it looks like i'm looking in the £200 ballpark which is a lot more than the DIY route...but I know i'm not looking at like for like here.
    I'll carry on drawing up the rough design & then look at the exact rail lengths involved.
    If i'm using aluminium profile for the table sides (I think the sides are 80x40 from memory), whats the best way to attach the supported rail to them given that the mounting holes won't match the slot spacing?
    Send Chai an email for quote here [email protected] with lengths and number of bearings and you may find it's bit cheaper.
    Either way i'd wait and save up a bit before take the DIY route because you will end up disappointed and wasting money trust me.!!
    Another thing to consider is the small extra investment will pay back big time further down the line when your ready to upgrade because you'll easily sell the machine and recoup most the cost (If done well you'll make money). DIY route you'll struggle get anybody to look at it and even then they'll want it for nothing.!!
    Also look at it this way your first DIY effort ended up in the bin so any outlay was lost.!! . . . . For the slight extra cost of doing with better materials it would still be alive, same goes here but this time you do plan on using better materials but will let the machine done with crappy DIY bearings. . . Better but only just.!!! . . .Not worth skimping on IME.
    You can just tap the profile but a better way is to fasten 10-12mm strip of aluminium with counter bored holes down centre and fasten into slots then fasten rail to that by drill/tapping into it.
    Problem with fastening straight to profile is there's not much material and the threads strip.!!
    Edit: Have you considered using steel.? It's much cheaper than Alu profile, stronger and taps no problem so no messing around.
  7. I have it in my head that i'll use supported rails now...I know that its worth the extra pennies. Looking at chucking a load of old hobby bits on ebay to help with the funding.
    I had previously been planning on using steel box - I think we exchanged messages about it ages ago.
    I like the convenience that ally profile offers - I also have concerns about getting a frame built with steel box square...although since looking at the supported rails I did think it could be easier to attach them to a frame made from box rather than profile.
    On the subject of rails, for a 2'x4' machine, what size rails would you recommend?
    I've just been reading a load of build logs & have seen mention that 20mm is overkill for a machine this size & that 16mm may be a better fit...but then there were comments about the bearing size being harder to work with - found it all a little less than clear :-p
    Personally, I really dislike the aluminium profile sections as they always feel a bit flimsy. I guess I've always made things in steel, so associate weight with strength. Your frame doesn't have to be perfectly square, it's the rails that have to be parallel and square to each other. The framework could easily be a couple of mm out of square and you'd still be able to build an accurate machine if you mount the rails correctly.
    What makes you think you'll get it any squarer using Profile than steel.? To be honest it's actually harder to get and keep square than steel.!
    With steel (presuming your welding) it's just case of tack it up knock square then when happy finish up the welds while keeping eye on it moving. After that it will never move again.
    With profile your messing around with corner diagonal braces and shims etc then first time you move it or shaking thing about a bit while cutting it's moved again.!!!
    Like Birchy says with steel it's strong and doesn't need to be micron square. The rails are what matter and steels much more workable than profile so more flexible regards alignment etc.
    By the time you have bought the profile and all the T-nuts etc which can cost has much has the profile you'll be into £200 plus with steel you'll do it for £60-80 and still have some left. That's £150 towards your rails.!!!
    Meant to ask this before.? What you doing regards screws etc . . Your not thinking threaded rod are you like lots of DIY rail folks do.?
    If so then again don't waste your time and go straight for balls screws and get them at same time has rails to keep costs down £300-£350, can get you a set of rails and screws with all end fixings and machining. Wouldn't or Don't even consider Lead screw has again it's not worth the small difference ballscrews cost.
    You'll have a proper machine that can do some serous work all day long and will be worth at least double the cost you put into it if done right.
    Steel is the way to go IMO Esp if your on budget. Profile looks bling but that's about the only thing it's got over steel all the rest that matters it's behind on.!!
  1. Replies: 0
    Last Post: 04-12-2011, 03:23 PM
  2. FOR SALE: 25mm Linear Slide bearings
    By D-man in forum Items For Sale
    Last Post: 28-11-2010, 05:14 PM
  3. Calculating forces on linear bearings ...
    By Jonathan in forum Rails, Guideways & Bearings
    Last Post: 24-11-2010, 02:26 AM
  4. Anybody used these linear bearings before?
    By pjl83 in forum Rails, Guideways & Bearings
    Last Post: 08-06-2010, 12:42 PM
  5. Play in linear bearings
    By leadinglights in forum Rails, Guideways & Bearings
    Last Post: 01-05-2010, 05:01 PM
