Thread: DIY Linear Bearings
Ok - it looks like i'm looking in the £200 ballpark which is a lot more than the DIY route...but I know i'm not looking at like for like here.
I'll carry on drawing up the rough design & then look at the exact rail lengths involved.
If i'm using aluminium profile for the table sides (I think the sides are 80x40 from memory), whats the best way to attach the supported rail to them given that the mounting holes won't match the slot spacing?
04-08-2013 #2
Send Chai an email for quote here [email protected] with lengths and number of bearings and you may find it's bit cheaper.
Either way i'd wait and save up a bit before take the DIY route because you will end up disappointed and wasting money trust me.!!
Another thing to consider is the small extra investment will pay back big time further down the line when your ready to upgrade because you'll easily sell the machine and recoup most the cost (If done well you'll make money). DIY route you'll struggle get anybody to look at it and even then they'll want it for nothing.!!
Also look at it this way your first DIY effort ended up in the bin so any outlay was lost.!! . . . . For the slight extra cost of doing with better materials it would still be alive, same goes here but this time you do plan on using better materials but will let the machine done with crappy DIY bearings. . . Better but only just.!!! . . .Not worth skimping on IME.
You can just tap the profile but a better way is to fasten 10-12mm strip of aluminium with counter bored holes down centre and fasten into slots then fasten rail to that by drill/tapping into it.
Problem with fastening straight to profile is there's not much material and the threads strip.!!
Edit: Have you considered using steel.? It's much cheaper than Alu profile, stronger and taps no problem so no messing around.Last edited by JAZZCNC; 04-08-2013 at 02:31 PM.
04-08-2013 #3
I have it in my head that i'll use supported rails now...I know that its worth the extra pennies. Looking at chucking a load of old hobby bits on ebay to help with the funding.
I had previously been planning on using steel box - I think we exchanged messages about it ages ago.
I like the convenience that ally profile offers - I also have concerns about getting a frame built with steel box square...although since looking at the supported rails I did think it could be easier to attach them to a frame made from box rather than profile.
On the subject of rails, for a 2'x4' machine, what size rails would you recommend?
I've just been reading a load of build logs & have seen mention that 20mm is overkill for a machine this size & that 16mm may be a better fit...but then there were comments about the bearing size being harder to work with - found it all a little less than clear :-p
04-08-2013 #4
Personally, I really dislike the aluminium profile sections as they always feel a bit flimsy. I guess I've always made things in steel, so associate weight with strength. Your frame doesn't have to be perfectly square, it's the rails that have to be parallel and square to each other. The framework could easily be a couple of mm out of square and you'd still be able to build an accurate machine if you mount the rails correctly.
04-08-2013 #5
What makes you think you'll get it any squarer using Profile than steel.? To be honest it's actually harder to get and keep square than steel.!
With steel (presuming your welding) it's just case of tack it up knock square then when happy finish up the welds while keeping eye on it moving. After that it will never move again.
With profile your messing around with corner diagonal braces and shims etc then first time you move it or shaking thing about a bit while cutting it's moved again.!!!
Like Birchy says with steel it's strong and doesn't need to be micron square. The rails are what matter and steels much more workable than profile so more flexible regards alignment etc.
By the time you have bought the profile and all the T-nuts etc which can cost has much has the profile you'll be into £200 plus with steel you'll do it for £60-80 and still have some left. That's £150 towards your rails.!!!
Meant to ask this before.? What you doing regards screws etc . . Your not thinking threaded rod are you like lots of DIY rail folks do.?
If so then again don't waste your time and go straight for balls screws and get them at same time has rails to keep costs down £300-£350, can get you a set of rails and screws with all end fixings and machining. Wouldn't or Don't even consider Lead screw has again it's not worth the small difference ballscrews cost.
You'll have a proper machine that can do some serous work all day long and will be worth at least double the cost you put into it if done right.
Steel is the way to go IMO Esp if your on budget. Profile looks bling but that's about the only thing it's got over steel all the rest that matters it's behind on.!!
04-08-2013 #6
Ok - so it looks like its about turn time & back to the drawing board.
Are we talking 50mm x 3mm mild steel box?
It'll be bolted, not welded as I don't have the gear for that - but I do have a pillar drill & some taps, so should be able to cobble something pretty sturdy together.
Screws - i was looking at a Marchant Dice package on ebay...but given that i'm now looking at supported rails from Chai, i think it makes sense to get some screws from him as well - i'll need to look at what he offers & the pricing. If the steel does work out that much cheaper, then the budget shouldn't be an issue.
I'll call my local metal supplier tomorrow to get a quote for the steel box & then start drawing something up.
04-08-2013 #7
Also, if you're following that design..... don't... the single central screw for the X-axis will cause you hours of pain if you plan to cut anything stronger than cheese at the full width of the Y axis. Plan and budget for two screws and either 2 drives & motors or a single motor and pulley system unless you make the x-axis bearings really long to counteract racking. Go re-read some of the build logs, its been discussed in depth many times. If you're investing in a serious machine, best to get it right at the outset!
04-08-2013 #8
While I agree completely 2 screws are best route in this case it's marginal Irving has he only wants 600mm cutting width, if he has wide enough bearing spacing on X axis and builds ridged Gantry it will be fine for upto light Aluminium work. On a budget this will work fine and with bit of thoughtful design could easily be incorporated later if needed.!!. . . . .Carry on Sir I say.
Yep 50 x 3mm and the last time I bought some which was 2-3months ago it cost me £26 for 7.5mtr length. That's was plus vat but if like my friendly supplier they will some times do without Vat.
04-08-2013 #9
FOR SALE: ballscrews, supported linear rails, linear bearings, complete kit. for sale
By cutter in forum Items For SaleReplies: 0Last Post: 04-12-2011, 03:23 PM -
FOR SALE: 25mm Linear Slide bearings
By D-man in forum Items For SaleReplies: 4Last Post: 28-11-2010, 05:14 PM -
Calculating forces on linear bearings ...
By Jonathan in forum Rails, Guideways & BearingsReplies: 7Last Post: 24-11-2010, 02:26 AM -
Anybody used these linear bearings before?
By pjl83 in forum Rails, Guideways & BearingsReplies: 9Last Post: 08-06-2010, 12:42 PM -
Play in linear bearings
By leadinglights in forum Rails, Guideways & BearingsReplies: 17Last Post: 01-05-2010, 05:01 PM
