Thread: DIY Linear Bearings
Personally, I really dislike the aluminium profile sections as they always feel a bit flimsy. I guess I've always made things in steel, so associate weight with strength. Your frame doesn't have to be perfectly square, it's the rails that have to be parallel and square to each other. The framework could easily be a couple of mm out of square and you'd still be able to build an accurate machine if you mount the rails correctly.
FOR SALE: ballscrews, supported linear rails, linear bearings, complete kit. for sale
By cutter in forum Items For SaleReplies: 0Last Post: 04-12-2011, 03:23 PM -
FOR SALE: 25mm Linear Slide bearings
By D-man in forum Items For SaleReplies: 4Last Post: 28-11-2010, 05:14 PM -
Calculating forces on linear bearings ...
By Jonathan in forum Rails, Guideways & BearingsReplies: 7Last Post: 24-11-2010, 02:26 AM -
Anybody used these linear bearings before?
By pjl83 in forum Rails, Guideways & BearingsReplies: 9Last Post: 08-06-2010, 12:42 PM -
Play in linear bearings
By leadinglights in forum Rails, Guideways & BearingsReplies: 17Last Post: 01-05-2010, 05:01 PM
