    Why would it not be possible simply to put a drag knife blade into the spindle (unbraked) and allow the spindle bearings to do the work? The spindle bearings are designed to cope with more than any loadings that card /vynal cutting would impose and provided that the spindle runs freely, I think that any of the offset round blades should work, provided that you can securely chuck the blade. I have not tried this but I will. I believe that most of the card/vynal cutters use a "nosing to set the depth and have a spring loaded "Z" to ensure the cut is limited to a set depth (that is how they can cut through the vynal leaving the backing sheet uncut. I would suggest that if using a drag knife in the router to place one of the "self healing" mats under the media. G.
    Sure someone must have tried it before now Geoffrey, I think these drag knife attachments are spring loaded to ensure the blade stays in contact with the media & cuts correctly, the way you are looking to try wouldn't have that ability.
    Other problem you might have is finding a blade with the right angle, a normal plotter blade is likely to be a bit to fragile for this sort of work so you would be looking at something a bit sturdier. Possibly scalpel or craft knife type blades.
  1. Looking for some CAM advice
    By m_c in forum Dolphin
    Last Post: 15-12-2013, 10:17 PM
  2. Its all about knowing when to give up!!!!
    By motoxy in forum Machine Discussion
    Last Post: 04-01-2013, 01:14 AM
  3. CNC construction TUNISIA give your comments
  4. NEW MEMBER: Hi from Derby and any locals want to give advice.
    By CharlieRam in forum New Member Introductions
    Last Post: 12-06-2011, 11:42 PM
