    maybe someone know good and cheap supplier for this type of drill bits? (subland? step drill?)
    I found a few suppliers but they are a bit too expensive for me, M6 bit over 40£+p&p
    Is this for counterboring caphead bolts? If so, why not use a proper counterbore?
    Counterbores - Arc Euro Trade
    7PC SOCKET CAP SCREW COUNTER BORES COUNTERBORE | eBay
  3. The Following User Says Thank You to birchy For This Useful Post:
    Quote Originally Posted by birchy View Post
    Hi birchi,
    yes, for cap head bolts, Thanks for the links!
    I've seen these drill bits, but I was not sure about them, since I'm a carpenter, so was looking for something similar to my tools
    Quote Originally Posted by Gytis View Post
    Use REAL tools not bent bits of wire
    John S -
  6. #5
    Thanks for another useful advice
  7. #6
    dazza's Avatar
    Lives in leicester, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 366.
    rather than start another thread does anyone know where i can find some counter bores this shape and size 6.3mm Cobalt Countersink Drill Bit 90° for Metal | eBay but with the little pilot bit on the end,i found some simular but they seem to be geared for wood work and have a drill bit running through the center,there not what im after.thanks
  8. #7
    That's a countersink not a counterbore? Big difference between the two. I also had a quick search for counterbores with a combined pilot drill so that you could effectively drill and counterbore without changing tools but came up blank. I've worked in engineering for many years but have never seen such a tool. Or at least not a proper one. I guess you'd have to get a lump of tool steel and make your own or make one by grinding a suitably sized drill bit.
  9. #8
    dazza's Avatar
    i must have dreamed them up then i was sure i had seen them before.ive got to use some counter sink allen bolts plan is to put in a pilot holes then manually counter sink the material on the bench drill,i can get by but would have prefered them to have that pilot guide on the bottom like those flat bottomed counter bores do
  10. #9
    Sorry, I misunderstood...I thought you meant pilot DRILL and countersink combined. There are things like these, but they look a bit Mickey Mouse to be honest...
    Countersink Cutter - 3/32" Rivet CC40 - Cleaveland Aircraft Tool
    Buy SNAPPY 7/64" x 3/8" Twist Bit Countersink For #6 Screws Fits Festool Centrotec Chucks at Woodcraft.com
    I mostly prefer to lock the work piece and then drill, change to tool and countersink. Bit of a PITA but it gives the best accuracy and squareness. If it's not too fussy, I use a cordless drill.
  11. #10
    dazza's Avatar
    Sorry, I misunderstood...I thought you meant pilot DRILL and countersink .
    its my fault fella (termonoligy how ever its spelt) its a piloted countersink im after doesnt have the drill going through it just a plain pilot on the end,ive found a few but its unlikley im gonna find the size i need so i,ll make do thanks.
  1. End mills / Drill bits for aluminium
    By ivars211 in forum Tool & Tooling Technology
    Last Post: 10-04-2014, 08:01 PM
  2. FOR SALE: dormer jobber A100 drill bits
    Last Post: 19-03-2012, 12:39 PM
  3. best drill bits
    By oadamo in forum Tool & Tooling Technology
    Last Post: 01-01-2011, 11:25 PM
  4. Center Drill Bits
    By Lee Roberts in forum Tool & Tooling Technology
    Last Post: 07-04-2010, 02:12 PM
  5. Split Point Drill Bits
    Last Post: 10-07-2008, 02:06 AM
