I recommend this archaic video if you are learning to stick weld...
www.youtube.com/watch?v=zWdgEaXWDxQ
The Following User Says Thank You to JoeHarris For This Useful Post:
11-08-2013 #2
11-08-2013 #3
Only trouble is how easy "max" makes it look to get a perfect weld!! I was more than a little disappointed with my first couple of attempts!
13-08-2013 #4
[QUOTE
Most of the frames I build are a mix of welded and bolted like these pics below. ( Frame only here no Bed, it's adjustable) [/QUOTE]
Jazz, do you mind explaining how the bed adjustment holes work on the frame pictured. It looks like you have another tapped plate or something inside the RHS? Cheers
joe
13-08-2013 #5
Yes there's a 10mm thick plate with holes tapped it.The holes in legs are drilled oversize for clearance. The 10mm plate is tacked in place to hold.
The main bed frame is heavy so there's 4 lead screws (2 each side) to help lift up and down and roughly get into position. Then there's 8 angle plates(4 each side) fastened to bed frame with 2 holes in each so 16 Bolts total that bolt into uprights with 10mm tapped plates inside.
It's simple and easy thou to be honest it's not something you do very often has usually you'll settle on a position that allows 90% of what you want to do.!. . . . It's just nice having the flexibility to do oversize things when needed.Last edited by JAZZCNC; 13-08-2013 at 07:09 PM.
16-08-2013 #6
Cheers. What thread are those then? I think I read somewhere that you favour m5 due to number of threads but they look bigger? What do you tend to use for plated connections?
[reason I ask is my 4.2mm bit is knakered and I'm looking at replacing it with a taper bit as my chuck is not the best... If m5 is not the way to go I may not bother just now..
JoeLast edited by JoeHarris; 16-08-2013 at 12:17 AM.
16-08-2013 #7
16-08-2013 #8
On the x-axis I am going to use 2 leadscrews with a single motor.
Ok - i'll draw up a revamped steel gantry...I have a slightly revised approach in mind now...i'll be back with a design for you to tut at later :-p
16-08-2013 #9
27-08-2013 #10
If you can get over the annoying accent there is a guy on YouTube called chucke2009 I think who does some handy trouble shooting videos on stick welding. I found them useful anyhow. Practice is key though I think...
BUILD LOG: Steel/Aluminium design/build, sorta smallish, cuts ali hopefully
By mart154 in forum DIY Router Build LogsReplies: 27Last Post: 19-09-2013, 05:48 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM -
