10-08-2013 #21
I understand that bit - its the 'weld plates bearing bolt holes to your bars you have a chance to straighten things up' bit that i'm not clear on the meaning of...
10-08-2013 #22
10-08-2013 #23
Anyway back on track.!!
Because using supported round rail then I wouldn't bother with Ecocast has the rail base will have more error than the steel. You only really needed plates between when fastening to Ali extrusion. If that's your plane then just buy normal Ali about 10mm.
If your meaning 5mm plate to sit on bearings then NO you'll need absolute minimum 10mm, 15-20mm is the norm.Last edited by JAZZCNC; 10-08-2013 at 12:30 PM.
10-08-2013 #24
10-08-2013 #25
10-08-2013 #26
Is this a thick fast cure resin, medium/slow cure with additive/filler or some sort of putty that i've not come across before?
In other news - i've ordered a 160A Arc welder via an auction on ebay...will need to pay a visit to my steel yard shortly to get some scrap to practice on.
The steel yard also sells welding rod - i'm assuming that because they do fabrication themselves they'll be decent rods...they do a box of ~250 6013 3.2mm for about £28+VAT - does that sound ok?
10-08-2013 #27
I recommend this archaic video if you are learning to stick weld...
www.youtube.com/watch?v=zWdgEaXWDxQ
The Following User Says Thank You to JoeHarris For This Useful Post:
10-08-2013 #28
11-08-2013 #29
11-08-2013 #30
You may be interested in my steel frame router Home Built GantryMill Improvements - YouTube the cutting area is 600mm x axis and 350mm y and 100mm z. It is built with materials I had to hand hence the mixture of steel and aluminum.
I would like to echo Robins comments about distortion caused by welding, it can be a nightmare so you will need to be very careful, also it is easier to weld thicker material but harder to remove the distortion.
Home
BUILD LOG: Steel/Aluminium design/build, sorta smallish, cuts ali hopefully
By mart154 in forum DIY Router Build LogsReplies: 27Last Post: 19-09-2013, 05:48 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM -
. . . .Oh and it's not expensive. 125g packs for £2 and it goes fair way has your only spreading thin, 2-3 tubes will do full machine.
. . .. Well not free suppose because I've paid for it when bought the bloody stuff it was covering. .
