    Joe I've drilled holes just less than dia of M12 nuts so tight fit then knocked the nuts into holes just below surface with bolt in threads to protect then weld in place then grind welds flush.
    I've got M12 bolts in 3mm box steel holding bearing blocks in place and never moved?
    Quote Originally Posted by Swarfing View Post
    You Lucky bugger it wouldn't work for me that's for sure it'd strip for sure guaranteed. .
    Loctited in position and no real forces so fine for my application
    Should have known.!! . . . Parcel tape and chewing gum. .
    Jazz my ex misses is on the prowl in wakefield tonight so bang one of your 16mm ballnuts in for me and tell her the backlash is way toooooo sloppy will ya
    Listen mate been there done all that (well not done her. . Lol) Honestly she's not even worth the words your typing.!!
    LOL! why do you think i left her for a CNC machine?
  8. Quote Originally Posted by JAZZCNC View Post
    Haha cheers guys! Trade secrets eh?!
  9. Ok - V2...
    Inner end pieces are 15mm plate
    Outer end plates are 20mm
    bearing blocks also beefed to 20mm
    Front plate is still 5mm - more to keep crap away from the leadscrew than perform a major structural role...although should help with twist & sideways flex.
    Rear stell plate removed - although that was there more for a convenient flat mounting surface rather than anything majorly structural.
    Still comes in under £100 - so that keeps me happy
ID:	9539   Click image for larger version.
    Better but still no inner triangle brace.!! See pic of brace on my machine. It's only a small thing but does help stiffen and dampen vibration more than it looks.
    Don't let Money run this Build too much because you could easily find you spoil it for not much more money.!! . . . Better waiting and saving up to do it right than skimp. It's a lot of work building a CNC machine and just small things that don't cost the earth can make a big difference.
  11. The Following User Says Thank You to JAZZCNC For This Useful Post:
  1. BUILD LOG: First steel diy CNC router build
  2. BUILD LOG: Steel/Aluminium design/build, sorta smallish, cuts ali hopefully
    By mart154 in forum DIY Router Build Logs
    Last Post: 19-09-2013, 05:48 PM
  4. BUILD LOG: 7' X 4' Steel frame build
