    Quote Originally Posted by CraftyGeek View Post
    So it turns out that welding is quite tricky to master...who'd a thunk?...more practice & video watching required
    Keep trying and it will click and don't get too stressed if your welds don't match those you see on the videos. Even pigeon shity looking will hold more than you realise. Weld 2 pieces together and then try to break the joint you'll be surprised how much effort it takes even with crap looking welds.!!
  2. Quote Originally Posted by JAZZCNC View Post
    I'm not stressing over it at all - i'll get it...not convinced i've got the current setting nailed yet. Welding lines & dots on a flat surface are coming out nicely - 'T' joins are a bit of a mess but solid. I think i've only used 3 rods so far...another 10 & I might get the hang of it.
    Overall though, I like it - very relaxing to do.
  3. Quote Originally Posted by CraftyGeek View Post
    Relaxing until you blow your nose after burning a few rods and realise you are coating your insides with filth!
  1. BUILD LOG: First steel diy CNC router build
  2. BUILD LOG: Steel/Aluminium design/build, sorta smallish, cuts ali hopefully
    By mart154 in forum DIY Router Build Logs
    Last Post: 19-09-2013, 05:48 PM
  4. BUILD LOG: 7' X 4' Steel frame build
