16-08-2013 #11
No but within reason, weight is your friend when cutting has it allows deeper depths of cut, obviously there's a limit and it affects other areas of machine like motors, drives, screws etc if you go too heavy. Stay within 80Kg and you'll be ok with steppers.!!. . . Heavier than this and you'll be into servo territory.
Doesn't really matter because all the adjustment is taken care of thru the rail mounting and were gantry sits on X axis bearings. . . The only requirement is that it's not twisted.
There are several ways to do different and I just drew this quickly to give an idea of easy and strong which go with single screw.
Really how you go about it depends on the job in hand, like in creakys case it was simple but would only really be suitable or woodwork type cutting any harder material like aluminium or if higher accuracy say for fine engraving, by that I mean in brass or Aluminium, PCB's etc where required then this is when weaknesses show thru quickly. . . . Resonance and vibration being the enemy has hollow aluminium box isn't stiff enough.! . . . It's also only works with twin screws and with single screw wouldn't be very good at all.!!
Your problem or complexity/weakness comes from using single screw.!!
BUILD LOG: Steel/Aluminium design/build, sorta smallish, cuts ali hopefully
By mart154 in forum DIY Router Build LogsReplies: 27Last Post: 19-09-2013, 05:48 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM -
