07-08-2013 #1
I've recently bought a Boxford TCL160 lathe that was already converted to Mach 3 by the previous owner. Everything seem to be working fine on it, but I noticed one thing that was wrong with it.
I noticed on the readout of the X axis that when the travel should be going X- the readout would be going X+. is there any quick way of sorting this problem out as I would really like to start using this lathe.
any help would be much appreciated.
thank you
07-08-2013 #2
If you go to the configuration dropdown menu & select homing/limits you have the otion to reverse the direction of any axis that is traveling the wrong way.
07-08-2013 #3
is it really that simple?? :-)
07-08-2013 #4
If you have a look in the mach3 manual it explains it.
I had the same thing when I first started running the machine I had refurbished. Worked like that for a while & was fine. Since then I have changed the axis around so the Y axis is now the x axis & vice versa. If you swap your x & y around you will probably find it does the same thing
07-08-2013 #5
thank you for the help. I will try that when I get home from work this afternoon and I will let you know. if that has sorted the problem.
once I edit the configurations, will this be saved for the next time i will turn on my machine or will I have to reset it again?
07-08-2013 #6
Mach3 will save any changes you make.
Boxford TUD conversion Mach USB
By Stucncusb in forum Boxford LathesReplies: 1Last Post: 21-06-2016, 09:40 PM -
FOR SALE: Boxford TCL160- Converted to Mach3
By FarrerDesign in forum Items For SaleReplies: 5Last Post: 26-06-2015, 09:52 PM -
Help Please With Auto Tool Height Mach 3 Problem
By howser37 in forum Probing, Digitizing & ScaningReplies: 26Last Post: 12-06-2014, 07:55 PM -
WANTED: Looking for a MKII Boxford duet for conversion to Mach 3
By BlueBot in forum Items WantedReplies: 0Last Post: 20-05-2014, 06:07 PM -
FOR SALE: For sale Boxford 125 part converted pc mack / ubuntu EMC
By Steve Beale in forum Items For SaleReplies: 0Last Post: 19-03-2011, 09:35 PM
