    Dean,
    Old but true saying.
    "If you have to ask you can't afford it "
    John S -
    The original posting said sub 10K euros, but did not specify machine specifications. G.
    Dean,
    I was asking for you John. . .
    Quote Originally Posted by GEOFFREY View Post
    £9,999 is Sub 10K.!! . . . Personally I like to know and sure has would others a No bull shit Firm price of standard Stepper driven Machine. With or without spindle.!!
    By standard I mean complete with fully working control box (with or without PC) and machine with limit switch's, home switches.
    Things like Probes, 4th axis etc are considered extra's IMO.
    Sorry I'm skint , just bought two of the new Nexus 7 tablets, awesome graphics, now gotta sort out how to run this Beaver mill off it ?
    John S -
    Dean, Geoffry and John - thanks for your input!! Cash is indeed king at the end of the day - But cash driven purchases can drive the total cost of ownership up - one has to look at the cost over the lifetime of the machine.
    Dean you summarised the options well - your no stranger to CNC. I shall try and be as comprehensive as possible with regard to the prices.
    Firstly the standard stepper driven machine comes with 48V switching PSU driving 3 Leadshine DM556's. Our motors are speced as high quality Oriental motors with 4.2A/phase with 1.6mH/phase winding inductance. Therefore the PSU voltage and motors are matched. Don't be seduced by cheaper motors with apparently high holding torque - the system must me matched to the application and to the PSU and drives.
    We have no "stand alone control box" for the machine. If you look at the machine bed at the back where the Tslot bed ends all the control gear is neatly housed away out of site. The only wires coming out of the machine are the 230V AC in and the control connection. With that said we are also working on a stand alone option for retro fit solutions.
    Attachment 9380
    So the professional platform has the following specs
    • T slot aluminium machine table
    • All three axes are driven by ball screws
    • 6,000mm/min feed rates
    • High power stepper motors
    • Accuracy repeatability down to as low as 0.02mmm
    • All control electronics fully installed
    • Machine wired for M03 and M05 AC on/off for spindle control
    • Latched on/off 24V DC safety for machine power management
    • Home switches on all three axes
    Machine options: The following prices are for the machine commissioned in Hereford UK ready for off (No PC)- delivery carriage / personal delivery can be discussed. Our prices are based on what we see necessary for a successful CNC machine sale. The sale in itself in our opinion is only half the story. Total cost of ownership to the customer must be considered. We offer 12 months warranty on all Hardware and do our best to provide the best support we can to our customers. We also do our best to work with our customers so that the machine can carry out its required function - and is specified appropriately. We offer pre-sale demonstration of a body of work to demonstrate the functionality if requested.
    • JBEC604012 (600 x 400 x 125) - 4,250£
    • JBEC106512 (1000 x 650 x 125) - 5,150£
    • JBEC1259012 (1250 x 900 x 125)- 5,980£
    I can post servo stepper prices if requested. We also offer a fully enclosed version currently available on the smaller 604012 machine. We can enclose the bigger machines and can discuss this further if requested.
    Spindle options: We offer Kress and high speed spindle options. The price includes integration of the spindle system into the machine. i.e the machine is ready for spindle addition - plugin and go - M03 & M05
    • Kress 1080FME 150£
    • 1.1kW High speed spindle option with inverter - full installed in the machine - 850£ (Comes with an ER20 compatible collet head)
    We can supply Kress collets and ER20 collets/accessories if needed. If you would like to use your own spindle we can fabricate you a custom mount.
    Control options: We can provide a refurbished PC with 12 months warranty in parallel to the machine if necessary. The machine can be run for 2D and some3D work on the LPT printer port connection and rapids as standard are set at up to 6,000mm/min. For full 3D machining we offer a USB upgrade. While I do not recommend it whatsoever - we have had the machine moving with rapids (single direction movement in either axis) of 15,000mm/min with the USB controller. We can demonstrate this if needed.
    • Mach 3 installation onto PC - 120£
    • Mach3 installation onto PC with USB upgrade installation combo - 220£ (150£ for installation 70£ for USB controller hardware)
    • Customers are responsible for their own license key for Mach3
    • Refurbished PC with all peripherals - 100-300£ model dependant.
    We will install and commission on a customers PC if required and the performance in the LPT printer port mode is subject to the PC Hardware passing the Mach3 driver test
    Maintenance While keeping the machine clean and free from swarf and potential hardware snags is essential for reliable operation - the machine is virtually maintenance free. The helical raceway inside the ballscrew drive mechanism can be lubricated using easily accessible grease nipples. There is adjustment options on the drives for long term wear. As of yet we have not had to do this on any of our installed platforms.
    Due to an unexpected rapid growth in demand here in Ireland we have minimal stock available for out launch into the UK. We will have a JBEC604012 and JBEC106512 ready by early September. Leadtime on a machine order that is not in stock is 6-8 weeks.
    We have put together the CNC package based on our own experience in CNC in recent years. The price to performance specs are such due to the clever design coupled with volume production of core sub assemblies in Germany. This coupled to our access to in house professional fabrication equipment enables us to provide and support such a machine and customise it appropriately.
    I hope the detail are clear.
    Hi Rory,
    So roughly £5500 for working Mid size machine with No PC or Spindle. . . .Thank you for a straight answer.
    I wish you well with this machine and it's well thought out and put together. The only thing that concerns me is the linear bearings.?
    At this money I would be expecting profiled linear rails, Looking at this machine it appears like it's using some Hybrid design.? Round rail in a machined housing.?
    Because of all the shielding etc which is good thing, but does always make me wonder is it for the right reasons or just hiding something not so desirable.? we can't actually see the bearings/carriage and type or how the ride on the rails.!! . . . . Would it be possible to see this area please.?
    Has you know and I know the linear rails are major part the machine and affect accuracy and quality of cut greatly so for this machine to stand the test of time the bearings/carriage design will need to be good. Even cheap bearings will last 12mth warranty period and for nearly 5K I'd be wanting and expecting maintenance free(other than lube) bearings for minimum 3-5yrs or better. So this would be an important and off putting if not decent quality design and bearings consideration for me.!!
    Rest of machine looks Spot on thou. .
    Oh Not keen on all electrics being housed in part of the main cutting frame, Shock vibration etc doesn't do most things any good. Then there's them pesky chips and coolant issues, esp if you plan on cutting aluminium which some will want to do, has even with air/mist coolant still collects and runs into cracks etc so hope it's well sealed.!
    Please don't think I'm trying to pull machine down, I'm honestly not. I'm just doing my usual close looking and pointing out things less experienced potential customers won't see. If experienced folks like me don't speak up then we end up with likes of Strike CNC taking folks for thousands.
    Dean.
    Edit: Ps. Would be nice to see pics of inside the Electrical housing so we can be sure there's no Ala Strike CNC booby trap surprises.!!
    Hi Rory,
    So roughly £4500 for working Mid size machine with No PC or Spindle. . . .Thank you for a straight answer.
    Dean.
    Dean - This is exactly the sort of involved feedback we are looking for and in our opinion it is very difficult to get people to think in this manner - thank you for taking the time to look over our system and highlight some very important considerations when looking at this type of router system. Typically with customers the price tag is king - but only half the story. And as you know only once you get to know the beast do you start to see the quirks.
    I am not familiar with Strike CNC? What was the story there with their "booby trap"? haha sounds like fun times :) Every minute your "bought CNC machine" is "not machining for you" or at the very least "in a position to do so" it is lost value to the customer. When I bought my first router I spent more time making it better than using it!!! Our experience with other low cost router systems have shown up common pitfalls in machine design. With that said low cost machines do teach people CNC and are accessible at their price. The problem is customers do not fully understand the limitations of such systems at the point of sale and this has created issues with support warranties etc. It is for these reasons that we have chosen the presented platform.
    And I'm 100% with you on the rail systems. The rail system is probably THE most important part of the entire machine design. Our ball screws are shoulder machined on both sides and sit fully supported at each end condition in the bearing housing. Therefore no load is transferred to the motor and there is no "rock" within the bearings in the frame. This design while generating excellent performance inherently challenges the gantry structure as the frame MUST be straight and 100% true to prevent lock up and jamming etc - this design demands flawless performance from the rail system. We have two ball-screws driving each gantry pillar on the main axis also. This is part of the reason we have such a stiff frame and supply a fully modular system. With the design there is no scope for misalignment of the gantry structure due to improper bench installation etc etc. However the trade off with the stiff heavy superstructure is that it does add to the cost but we feel its more than justified.
    Our rail system is custom built in Germany - I won't go into specifics until I have pictures to support explanations - early next week at the latest.
    The electronics are safely sealed away - all the cover panels are CNC cut and are sealed with sealant around the edges. The Tslot table end condition also provides a level of drip creep prevention from pesky coolant :) More details to come ASAP also there
    We have had customers hammering 3D work in hardwood with no issues on full time production. The drive and PSU mount layout has heat-sink properties and there is also room for adding control boards if necessary for advanced machine variations.
    We have a machine in a stage of assembly that that will suit to support the information you are after. I will be working on the machine on Monday and will take some sample pictures of the considerations you have highlighted. Is there anything else you would like to see while the opportunity is there?
    Also - can you point me in the direction of a possible show/fair/expo where a stand would cross paths with the wider CNC community? We prefer potential customers seeing it in the flesh.
  1. Gerber system 48
    By martin54 in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2013, 12:35 PM
  2. JBEC router system UNDER THE BONNET
    By StoneyCNC in forum Manufacturer News
    Last Post: 10-09-2013, 06:05 PM
  3. Gerber system 48 Plus router
    By poppa jock in forum Machine Discussion
    Last Post: 29-07-2013, 05:43 PM
  4. My Coolant System
    By Tenson in forum Swarf & Chip Management
    Last Post: 08-04-2013, 01:59 PM
  5. Diy Self Leveling System
    By Ricardoco in forum Gantry/Router Machines & Building
    Last Post: 17-07-2012, 11:12 PM
