08-08-2013 #8
Hi Rory,
So roughly £5500 for working Mid size machine with No PC or Spindle. . . .Thank you for a straight answer.
I wish you well with this machine and it's well thought out and put together. The only thing that concerns me is the linear bearings.?
At this money I would be expecting profiled linear rails, Looking at this machine it appears like it's using some Hybrid design.? Round rail in a machined housing.?
Because of all the shielding etc which is good thing, but does always make me wonder is it for the right reasons or just hiding something not so desirable.? we can't actually see the bearings/carriage and type or how the ride on the rails.!! . . . . Would it be possible to see this area please.?
Has you know and I know the linear rails are major part the machine and affect accuracy and quality of cut greatly so for this machine to stand the test of time the bearings/carriage design will need to be good. Even cheap bearings will last 12mth warranty period and for nearly 5K I'd be wanting and expecting maintenance free(other than lube) bearings for minimum 3-5yrs or better. So this would be an important and off putting if not decent quality design and bearings consideration for me.!!
Rest of machine looks Spot on thou. .
Oh Not keen on all electrics being housed in part of the main cutting frame, Shock vibration etc doesn't do most things any good. Then there's them pesky chips and coolant issues, esp if you plan on cutting aluminium which some will want to do, has even with air/mist coolant still collects and runs into cracks etc so hope it's well sealed.!
Please don't think I'm trying to pull machine down, I'm honestly not. I'm just doing my usual close looking and pointing out things less experienced potential customers won't see. If experienced folks like me don't speak up then we end up with likes of Strike CNC taking folks for thousands.
Dean.
Edit: Ps. Would be nice to see pics of inside the Electrical housing so we can be sure there's no Ala Strike CNC booby trap surprises.!!Last edited by JAZZCNC; 08-08-2013 at 01:22 PM.
Gerber system 48
By martin54 in forum Milling Machines, Builds & ConversionsReplies: 67Last Post: 13-09-2013, 12:35 PM -
JBEC router system UNDER THE BONNET
By StoneyCNC in forum Manufacturer NewsReplies: 24Last Post: 10-09-2013, 06:05 PM -
Gerber system 48 Plus router
By poppa jock in forum Machine DiscussionReplies: 0Last Post: 29-07-2013, 05:43 PM -
My Coolant System
By Tenson in forum Swarf & Chip ManagementReplies: 6Last Post: 08-04-2013, 01:59 PM -
Diy Self Leveling System
By Ricardoco in forum Gantry/Router Machines & BuildingReplies: 19Last Post: 17-07-2012, 11:12 PM
