So good news and bad news. I got cold feet over going straight to 15v, so bought a few trannys of different volts and started with 6 + 6 which was a no-go. 9 + 9 = no-go
Then at 12 + 12 and the controller would run the motor, but only for a moment.
I then tried the 15 + 15 and same result, the controller would only jog the motor.
No amount of twiddling IR or Imax made any difference, seems the current feedback circuit had a problem.
Bridging out the load resistors made no difference.
The bad news is obvious - couldn't get it to run properly, the good news is that a 15 + 15v transformer is probably correct.
Mach lathe spindle speed control
By GeoffV in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 21-05-2014, 08:34 AM -
FOR SALE: pdmx 107 spindle speed control board
By dazza in forum Items For SaleReplies: 0Last Post: 08-05-2014, 02:58 PM -
Spindle Speed Control
By cncJim in forum Spindles & Drive MotorsReplies: 15Last Post: 18-06-2013, 07:53 PM -
Speed control
By Saracen in forum Spindles & Drive MotorsReplies: 2Last Post: 29-12-2012, 02:18 PM -
How to control fan speed?
By Smiler in forum General ElectronicsReplies: 5Last Post: 28-07-2011, 09:48 AM
