08-08-2013 #1
This might be very basic, but I'll ask anyway.
What's the standard fit for a pulley on a shaft? got some pulleys from beltingonline and the one which fits on the motor shaft, which has a 5mm keyway and two grub screws looks like an tight fit, ie. I have to push down really hard on the pulley to get it on the shaft and even then it doesn't go all the way. I'm a bit reluctant to use more force as:
a) not sure what the shaft can take
b) not sure I'll be able to pull it off later
I think it gets a bit tight around the key, which seems pressed into the keyway on the shaft. Is it a good idea to grab some super fine sandpaper and run it around the sides of the key to take a tiny bit off and make fitting easier? if I'm talking crazy feel free to hit me.
Regards,
dsc.
misaligned keyway - stepper shaft vs pulley
By dsc in forum Stepper & Servo MotorsReplies: 9Last Post: 25-02-2014, 03:25 PM -
AC Motor upgrade - pulley sizes
By birchy in forum Linear & Rotary MotionReplies: 7Last Post: 21-06-2013, 10:49 PM -
16 tooth pulley HTD5 15mm on a 14mm shaft
By dsc in forum Belt Drive, Pulleys & TimingReplies: 6Last Post: 07-06-2013, 11:51 AM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM
