    It should be tight but not need twatting on with a hammer. Deburr the keyway and give the shaft a light rub with some wet & dry. It'll probably fit ok then.
    Depending on the fit it has been machined to it might require a percussion adjuster. Colour in the shaft with a black marker, if you havent got any blue, then try to fit the pulley. Hopefully you will see where it is binding ie like the key is too high maybe. If its tight all round it might just be the fit. Whack the pulley in the oven for 10 minutes then drop it on.
  1. misaligned keyway - stepper shaft vs pulley
    By dsc in forum Stepper & Servo Motors
    Last Post: 25-02-2014, 03:25 PM
  2. AC Motor upgrade - pulley sizes
    By birchy in forum Linear & Rotary Motion
    Last Post: 21-06-2013, 10:49 PM
  3. 16 tooth pulley HTD5 15mm on a 14mm shaft
    By dsc in forum Belt Drive, Pulleys & Timing
    Last Post: 07-06-2013, 11:51 AM
  4. Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
    By LoveLearn in forum Gantry/Router Machines & Building
    Last Post: 08-02-2012, 01:52 AM
  5. Stepper shaft size and pulley bore size problem
