Ralph Waldo Emerson
09-08-2013 #2
Forget it, you are still into the realms of big boys toys, plenty of space needed, big power supplies and the gas bill alone would be enough to put you on oxygen but you wouldn't be able to afford it
Find a decent company and outsource it, however no one is going to engrave 1mm deep, that's rotary tooling territoryJohn S -
09-08-2013 #3
Ralph Waldo Emerson
09-08-2013 #4
As John says engraving to that depth aint going to look nice on a laser because you are cutting rather than engraving.
Can you get them plasma cut and finish them?
09-08-2013 #5
Why does 3.5KW require 200A per phase three phase? 200A = 240,000KW
09-08-2013 #6
The 3kw is laser ouput and they are not that efficient, plus there are the chiller units, CNc bit, table etc, the laser bits and all the ancillaries like sheet loading, crane, bed changing etc.
OK I know these are not needed for a small operation but at 300K a pop for a laser you DO WANT all the bells and whistles.John S -
09-08-2013 #7
I can do them nicely on the CNC it’s just like i said the faffing around. I don’t have a vac table so I have been making homemade clamps. Plasma if the stuff I get off AW is an awful edge when cut. It was just speculation, I can carry on as I am quite easily until I need a hundred done at any one time then I’ll phone around for price.
Ralph Waldo Emerson
laser cutter/engraver rebuild build log
By gavztheouch in forum Laser Machines & BuildingReplies: 37Last Post: 10-11-2015, 05:37 PM -
Laser Cutter Operative Frome, Somerset
By Frome-laser-cutter in forum Opportunities Available & SoughtReplies: 0Last Post: 13-02-2014, 04:16 PM -
Hand held laser cutter
By Robin Hewitt in forum Tool & Tooling TechnologyReplies: 9Last Post: 24-10-2013, 06:05 PM -
Laser cutter
By John S in forum Laser Machines & BuildingReplies: 8Last Post: 02-06-2012, 02:16 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM
