	09-08-2013 #1
Hi guys and girls i have the above for sale with tooling and vice and comes with computer with software
its currently in my unit and can be seen working and can do a full demo for the new owner
the story is i brought the machine off a friend and he has had it from new to basically learn how to use it and make my own custom parts as he upgraded to a massive Hurco machine
but due to work being mega busy i have been unable to spend anytime learning it and all the parts ive needed making they do on there other machine
so instead of just sitting in my unit i have decided to sell on so someone else can have some fun
it really is a great machine and in the right hands is a key to print money
the specs below from there website
Key Features
Fully enclosed high precision 1610 series machining center
High dynamic stiffness and class defining absolute accuracy
Struture verified in excess of 10,000 hours of field testing
Industrial and commercial use designation
Anzi Z535.4 labeling compliance, UL, ETL and CE listed components
Fits in just 3' x 5' floor space
G3000 35KSI low silicon grey cast iron Virgin castings, FEA optimized
~ 16 " x 10 " x 16 " XYZ travel
30 " x 9.5 " table, 5/8" slots
3 Hp spindle with R8 taper - Manual tool change
310 - 5000 Spindle RPM with ISO P4 bearings
H class linear guides on all axis
JIS C3 Class ground ball screws
Only requires 220 VAC 1 phase power
Weighs only 2000 lbs
Integrated 4 axis MIKINI V2.02 CNC & Manual control system
Instant and digitally averaged spindle load metering
Coolant system included, installed and tested (standard)
Manual pendant (standard)
Stainless tooling / keyboard shelf (standard)
Fully cast stand (standard)
Instant Manual feed rate calculation
4 axis manual DRO
Optional industrial PC CNC controller
Fully cast base accommodates easy movement
Automated 15 point oiling system (standard)
i can get lots of pics up asap
the unit is in my workshop in wokingham berkshire and i have access to a forklift to lift onto a trailer
im looking for £8500 ono
you can contact me on 07904812752
many thanks
clive westall
or email @ [email protected]
	11-08-2013 #2
All offers considered try me :-)
	15-08-2013 #3
Isn't that close to the new retail value?
	15-08-2013 #4
No not when you price it with tooling + vice + software+ taxes+shipping
8k Ono
If you look at what it can do and it's a full enclosure this is a good price IMO
	16-08-2013 #5
Fair enough - no offence intended. 3k out of my price range I'm afraid.
	18-08-2013 #6
I could go as low as 7500 if that helps but that's the min I will not sell lower
Awesome bit of kit
	26-08-2013 #7
price drop to £7000
pics will be added on tuesday
	28-08-2013 #8
What ever happened to the likely lads? errr I mean pictures?
	28-08-2013 #9
Sorry been having issue pics was on my iPhone that failed got new iPhone 5 today took some more pics to send to another guy but won't send !! Trying
What's your mob number I will see if I can send them to you failing that I need to try and upload to here but haven't a clue how to!!!
The new probe and finding the center of a hole
By Ricardoco in forum Probing, Digitizing & ScaningReplies: 9Last Post: 13-11-2015, 06:43 AM -
Vertical Machining Center Info
By benkat in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 13-04-2012, 03:12 PM -
mechatronics board
By edgas10 in forum Motor Drivers & ControllersReplies: 4Last Post: 25-04-2011, 10:44 PM -
Center Drill Bits
By Lee Roberts in forum Tool & Tooling TechnologyReplies: 21Last Post: 07-04-2010, 02:12 PM -
Help with mach3 center finding script
By eddie60 in forum Programmers CornerReplies: 7Last Post: 20-05-2009, 06:23 PM
