  1. #15
    Prefer the tube approach as less inertia as well.
    Whats your view on 1 v 2 clamp bolts?
    Personally I'd have gone for solid and let me take the weight out of it by boring.!
    Regards clamps bolts then probably 2 has it will clamp more even. How many bearings are you planning on using.?
    Also the specs for 6900zz are 22x10x6 and if this is being assembled like I think (see pics) then you have allowed for 2 bearings @8mm is this correct.?
    See pic6 and you'll see what I mean with 6mm bearing and 4mm spacer between, it leaves shaft sticking out.!
    Let me know if I'm wrong and if this is the final drawing.
    cheers
    Dean.
ID:	9435   Click image for larger version.
ID:	9434   Click image for larger version.
ID:	9436   Click image for larger version.
ID:	9437   Click image for larger version.
ID:	9438   Click image for larger version.
  1. Second hand machines & their features
    By navins in forum Machine Discussion
    Last Post: 19-03-2014, 11:01 AM
  2. Hand Ergometer
    Last Post: 11-08-2013, 05:55 PM
  3. 75 mm HAND WHEEL
    By Lee Roberts in forum Programmers Corner
    Last Post: 19-03-2012, 02:58 PM
  4. NEW MEMBER: want buy new or second hand cnc
    By buildwood in forum New Member Introductions
    Last Post: 20-10-2011, 05:36 PM
  5. NEW MEMBER: second hand machine
    By steve r in forum New Member Introductions
    Last Post: 18-11-2009, 09:00 PM
