    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 22 Hours Ago Has been a member for 9-10 years. Has a total post count of 799. Received thanks 99 times, giving thanks to others 176 times.
    Hi irving
    If i was making the handle assembly i would manufacture from one piece of ally with an interference fit for your two bearings. also make the 150mm length 22mm Dia & then you can fit some proper cycle handlebar covers.I bought that ring gear just to see if i could work out the gear form(probable modular) don't know if the required wheel size will mesh though as the mating components from the hub it came from are rather small.
    Take care M8
  2. Quote Originally Posted by mekanik View Post
    Hi irving
    Take care M8
    Thanks for your input.
    I had considered machining it from the solid but thats a huge amount of wastage of a 65 or 70mm bar x ~350mm. Thats over £50 +p&p on ebay to throw 50% away! However if someone wants to provide the stock for free then I'm not proud
    Not sure a pure interference fit would be stable enough and all the designs i looked at use a clamp arrangement with either one or two clamp bolts. Two bolts might be overkill tho.
    The diameter of the grip needs to be much bigger than a normal cycle handle bar as I cant wrap my fingers that tightly. The 32mm dia is the same size as the one I use at the rehab unit and will be wrapped in bar tape or sleeved with rubber tube heatshrunk on.
    No problem if you want it from Solid Irving I can sort that, thou it will mean a slight delay has I have to get from a mate.
  4. Quote Originally Posted by JAZZCNC View Post
    Prefer the tube approach as less inertia as well.
    Whats your view on 1 v 2 clamp bolts?
    Updated drawings attached. I've only taken the radial slot down to the top of the bearing, think that'l give enough movement?
    Attached Files Attached Files
  5. #15
    mekanik's Avatar
    If made from solid you could place one bearing in the centre of the handle and one @ the end
  6. Quote Originally Posted by mekanik View Post
    My original design was like that but with a bearing insert at the far end of the tube, means a longer axle of course. But none of the commercial units are like that as they offer a range of handle shapes (i.e. bent tubes) for different disabilities so really I'm copying a tested approach.
  7. #17
    mekanik's Avatar
    Understand now but if you do not intend to add various extensions your first idea is a better/stronger design,also you would not need the pinch bolts and the slot that is going to weaken the assembly @ the point of most strain, making a shaft with a step to locate the bearings so they are captive on the shaft. if that makes any sense, unfortunately i am not proficient with sketchup as i could better explain with a drawing.
    regards
    Mike
  8. #18
    Personally I'd have gone for solid and let me take the weight out of it by boring.!
    Regards clamps bolts then probably 2 has it will clamp more even. How many bearings are you planning on using.?
    Also the specs for 6900zz are 22x10x6 and if this is being assembled like I think (see pics) then you have allowed for 2 bearings @8mm is this correct.?
    See pic6 and you'll see what I mean with 6mm bearing and 4mm spacer between, it leaves shaft sticking out.!
    Let me know if I'm wrong and if this is the final drawing.
    cheers
    Dean.
ID:	9435   Click image for larger version.
ID:	9434   Click image for larger version.
ID:	9436   Click image for larger version.
ID:	9437   Click image for larger version.
ID:	9438   Click image for larger version.
  9. Dean,
    If you prefer to machine from solid and dont mind the wastage feel free I went for the lowest cost approach.
    When you say 'shaft sticking out' I assume you mean the inner end of the axle? Thats why there are 2 spacers, the second goes on the end of the axle and a standard M8 nyloc nut & washer bears against it. I did it this way as in the past i found a M8 nut is too large and fouls the bearing outer race (da max for bearing 12mm, A/C for nut is 15mm) and turning an M8 washer down to 12mm is fiddly.
    But if you have a better solution....
  10. #20
    Dean,
    Ok will do not a problem just small delay on material, which I've sorted. I Should have material for weekend so will do it then.
    Ah ah my mistake didn't see x 2. . . . Lol . . . . Thou think it better to space the bearings far apart has possible so I'd be inclined to make a washer, so I'll do that if you don't mind. I'll make wider spacer and turn a washer down, turning washer down is easy enough so no problem.
    Like this. Click image for larger version.
  1. Second hand machines & their features
    By navins in forum Machine Discussion
    Last Post: 19-03-2014, 11:01 AM
  2. Hand Ergometer
    Last Post: 11-08-2013, 05:55 PM
  3. 75 mm HAND WHEEL
    By Lee Roberts in forum Programmers Corner
    Last Post: 19-03-2012, 02:58 PM
  4. NEW MEMBER: want buy new or second hand cnc
    By buildwood in forum New Member Introductions
    Last Post: 20-10-2011, 05:36 PM
  5. NEW MEMBER: second hand machine
    By steve r in forum New Member Introductions
    Last Post: 18-11-2009, 09:00 PM
