Thread: Resistor Calculator
16-03-2009 #1
As it says on the "Tin":
.Me
17-03-2009 #2
Just be careful, that equation assumes the LED requires 20 milli Amps of current, the proper equation is (Vsupply - Vled) = IR, or R = (Vsupply - Vled) / I in this case. V is in Volts, I is in Amps, and R in Ohms.
20 mA = 0.020 Amps.
Some minature LEDs go pop on less than 20mA :)
Technically speaking LEDs require a certain current, not a certain voltage, so it is possible to run a LED from a higher voltage supply without a current limiting resistor, as long as the supply is switched so that the average current is at or below the LEDs forward current.Last edited by ZeroCount; 17-03-2009 at 12:58 AM. Reason: Additional information
The more I learn about this hobby, the brighter the light of knowledge grows, the deeper is the pit of ignorance revealed...
17-04-2012 #3
I'm using this online calculator - you will also get the power requirements for the resistor - it calculates the Wattage of the resistor - depending of the voltage of the circuit
http://led.linear1.org/1led.wiz
The Following User Says Thank You to karul For This Useful Post:
cnc machine stiffness calculator
By routercnc in forum Linear & Rotary MotionReplies: 13Last Post: 02-09-2022, 04:32 PM -
Simple O-ring calculator.
By jcb121 in forum General ComputingReplies: 4Last Post: 26-07-2013, 09:00 PM -
Resistor Question
By GTJim in forum General ElectronicsReplies: 1Last Post: 07-04-2013, 10:01 AM -
ATX power supply - load resistor - do I need one ?
By rckeith in forum General ElectronicsReplies: 4Last Post: 18-08-2010, 03:21 PM -
What type of resistor?
By Smiler in forum General ElectronicsReplies: 4Last Post: 05-12-2008, 10:04 PM
