    got these from a scrap machine, as they look quite professional though maybe i could use them on my upcoming build, i considered if i could connect the break out board correctly it should work (should is the magic word), after all it only needs a few wires connecting to get it going, i did like the fact it only needs 240v kettle lead to work , no need for power supplies although i did get a switchmode supply and a 4 way indexer which im sure i dont need, cheers Nik
Name:	2013-08-11 16.01.43.jpg
Name:	2013-08-11 16.11.19.jpg
    btw machine was scrapped due being a spare and then technology left it behind
    Looks like step and direction into 1 and 2 then 14 and 15 link together and go to ground on the BOB
    No idea how you set amperage though ?
    John S -
  4. any part numbers or other identifying marks?
    Looks like the dip switches at top John.?
    Can you show pic of those switches Drnik.
  6. The bottom 3 switches of the top bank are labelled 'motor curr'. Also 2 switches labelled 'resn' I'd guess are microstep setting?
    More intriguing are the 'setup' trimmers for accel, etc.
    Hi John
    We use this Parker equipment at work send me a pm with the model numbers I think we will have the manuals for them.
    Andy
    You can tell I hav'nt been on here for a long time!
    Nick send me your details including model numbers I,m sure I can help.
    Hi Irving
    These are used with DIP Switch 3 where you can have internal speed control.
    well cheers Andy, i'll post these pictures
Name:	2013-08-15 19.03.26.jpg
Name:	2013-08-15 19.03.36.jpg
    i also got this as it was attached to the 3 drivers, im not going to be using it,
Name:	2013-08-15 19.03.49.jpg
  10. Manual here http://www.parkermotion.com/manuals/PD/PDS_E.pdf‎
    2.5A min, 5A max driver in 350mA steps
    step settings 400, 1000, 2000, 4000 (i.e. 1/2, 1/5, 1/10, 1/20)
    opto-isolated inputs
    regenerative dump circuit
  1. Cast aluminium gantry router
    By jrcast in forum Gantry/Router Machines & Building
    Last Post: 17-02-2017, 08:13 PM
  2. Semi - Experienced / Experienced CNC Turner required in Rutland
    By ChrisMunday in forum Opportunities Available & Sought
    Last Post: 05-02-2014, 11:08 AM
  3. Epoxy cast plastic injection tools
    By gavztheouch in forum Moulding Machines
    Last Post: 27-01-2014, 11:33 PM
  4. RFQ: Marking a cast iron
    By mike stat in forum Projects, Jobs & Requests
    Last Post: 13-09-2012, 10:22 PM
  5. Can anyone recommend a spindle for milling PCB and cast acrylic?
    Last Post: 11-10-2011, 08:54 PM
