Thread: Wobblycogs CNC Mk2
20-08-2013 #11
Absolutely would go bigger and even at 60x90 you won't be over building believe me.!! . . like the Famous film words.? "Don't under estimate the force" Wobbycogs.!!
Either has you can always pack for clearance and it keeps Z axis compact and light. Bigger will give clearance at the cost of weight and extra standoff.
Yes use a 10mm plate but wouldn't bother with tooling plate has the rail base will have more error than the standard plate so waste of money if your not going to skim the rail base.!
If it will cut Ali properly then it will cut brass Ok.
BUILD LOG: Wobblycogs CNC Mk1
By Wobblycogs in forum DIY Router Build LogsReplies: 91Last Post: 02-01-2013, 07:38 PM
