    One beefed up gantry with added sides. Now I draw it I can see this is significantly stiffer than what I had, I was relying on the 10mm plate not bending along it's weakest axis, doh!
Name:	2013-08-23 better gantry side 2.png
ID:	9740Click image for larger version.
Name:	2013-08-23 better gantry side 1.png
    As you suggest there will be 3*10mm thick plates on the back with the rest covered with a thin sheet. The front will be a full 10mm sheet with a slot for the ball screw. Feel free to imagine bolt holes all over the place ;-)
    Thanks again for all the help.
    EDIT:
    There you go it's drawn up
Name:	2013-08-23 better gantry side 3.png
    It's close very close but not quite Carling.!!. . .Lol
    Gantry's fine but those drop brackets for X axis ballnut mounts are too flimsy so make bit wider at top and beef them up a bit and your there.!
    Gantry's fine...
    I've bunked off work for the afternoon to do some CNC design so I'll get those x-axis brackets beefed up a bit. I'm also swapping the ballscrew and stepper around inside the gantry (so the screw is at the top) that way the slot is further from the chips.
    I've been reading a few posts of yours regarding aluminium machining. I'm going to have a crack at using my circular saw to cut most of the pieces and then clean up with a router bit. I've tried routing aluminium in the past but only 5mm sheet. It went well but I'd agree with you it was scary at first.
    I was also having a read up on pulleys. I've got 9mm 16 tooth on there at the minute but I think I'll upgrade them to 15mm 20 tooth (all HTD5). Will a 15mm pulley (like this) mount cleanly onto the shaft of a typically 3Nm stepper? I'm just a little concerned because the L dimension on the pulley is 26mm and the shaft of the stepper seems to only be 16 to 24mm long depending where I look.
    P.S. Bloomin' love this design by the way. Once I have my workshop built I think there might have to be a bit of creative copying for CNC number 2
    Another weekend comes and goes with much work on the house and little on the CNC, sigh. Anyway, after getting a tick for the gantry I've been going around the design putting in all the bolts. I figure it's better to find bolt hole collisions at this stage rather than when I come to build the machine. It's a really slow process even (even using the hole wizard) but I think it's worth it. For example I thought most holes would be using M5 bolts with some M6. In reality it's turned out most will have to be M4 with some M5. Also the thread depth on the linear bearings is surprisingly short so some careful counterboring will be required. The Z-axis stepper has grown a bent metal box cover. I'll probably end up adding a hinged flap on the front at some point - there was a front originally but I realized would wouldn't be able to fit the stepper through the hole I'd left!
ID:	9781Click image for larger version.
ID:	9782Click image for larger version.
ID:	9783Click image for larger version.
ID:	9784Click image for larger version.
    The X-Axis is still has quite a bit of work to be done on it. As you can see there's no stepper, pulleys etc. The rails and screws are in the final location though as this is dictated by the rails. After reading this thread I'm toying with the idea of designing in the ability to use liquid coolant when cutting aluminium, I suspect that might be biting off more than I can chew at this stage though. I think I'll keep it in mind as a potential future improvement.
    The rails, fingers crossed, should be with me fairly soon. Parcel Farce reports that they are in the country awaiting customs clearance. So far my first purchase from the far east seems to be going smoothly. Phew.
    I got to thinking over the weekend about whether I would manage to finish this project (actually when because I'm going to finish it if it kills me) and it occurred to me that a lot of projects don't seem to make it past the planning stage and a good few seem to fail in the building stage. I wonder what percentage of people who want to build a CNC actually finish the task and end up with a machine that works (at least reasonably well).
    Quote Originally Posted by Wobblycogs View Post
    I would make the Z front plate just bit narrower than Rear plate and put a full cover over the z axis so it protects rails and everything.
    Easy done with 1.5mm Ali sheet, just make a cardboard template and then cut around. Don't need fancy bender or saws just score profile edges with stanley knife, trim with tin snips into straight length then bend to break off.
    Easy folded with simple scores on fold lines (back side.!!). The pics below show cover which was folded by hand without clamping to make a permanent template then unfolded, (see pic.). . . If you clamp the sheet on top surface before folding and fold on edge of board then makes a better fold.
    Takes about 30mins to make.!!
ID:	9791   Click image for larger version.
ID:	9790   Click image for larger version.
ID:	9789   Click image for larger version.
ID:	9788   Click image for larger version.
    That looks more like a tank than a cnc machine :-). I bet it effective at keeping the chips out though.
    Well, I've been hard at it putting bolts in the design and I think I've got to the point were there's not much point adding any more as they clearly wont clash. So with that done here are some shots of what will get built unless anyone comes up with a show stopper. my estimate for maximum cutting sizes are X: 840mm, Y: 840mm and Z: 125mm assuming a 50mm bit. I cab squeeze a bit more out of Z by moving the spindle up a series of holes.
Name:	2013-08-31 yz-detail.png
ID:	9922Click image for larger version.
Name:	2013-08-31 x-detail.png
ID:	9923Click image for larger version.
Name:	2013-08-31 x-stepper and cable management.png
ID:	9924Click image for larger version.
ID:	9925Click image for larger version.
ID:	9926Click image for larger version.
Name:	2013-08-31 front.png
ID:	9927Click image for larger version.
ID:	9928Click image for larger version.
Name:	2013-08-31 perspective.png
ID:	9929Click image for larger version.
Name:	2013-08-31 bottom.png
  7. Is the plan still to mount it vertically?...how is it going to be attached to the wall?
  1. BUILD LOG: Wobblycogs CNC Mk1
    By Wobblycogs in forum DIY Router Build Logs
    Last Post: 02-01-2013, 07:38 PM
