Thread: Wobblycogs CNC Mk2
19-09-2013 #11
You could do it that way, but in Mach3 people like to home each X-axis motor separately to square the gantry, which clearly can't be done with them both connected to the same output. I'm not keen on that method as it bends the gantry, albeit only slightly, every time you home the axis.
Yes, that's correct although it can be inverted.
BUILD LOG: Wobblycogs CNC Mk1
By Wobblycogs in forum DIY Router Build LogsReplies: 91Last Post: 02-01-2013, 07:38 PM
