    Occaisionally, I check the squareness of my machine by drilling 3 holes to prescribe a right angled triangle and accurately measure their center distance to determine skewness, and proceed to compensate back to square. I've taken to putting marks on the rotating ballnuts to aid the correction process.
    Ok but why would you need marks on rotating nuts to aid correction if it never loses a step or position.?? Should be nothing to correct.!!
    I've never seen the machine loose or gain even just one microstep on either motor, except when I've crashed it. That's including on a job where the machine was left running for the best part of 47 hours.
    But what was you cutting and at what feeds.? . . Aluminium I presume.! . . . Try cutting wood with inertia of rotating screws not rotating nuts around 7-8mtr/min for 47hrs and check it.!!
    Also your machine is setup correctly and presumably with plenty of torque left, I'm talking higher feeds and motors tuned close to edge which often happens causing lost steps and much sooner than 47hrs.!!
    Again I'll say it " Tune the motors properly with plenty of safety margin and there's no problem with slaved motors" but still it can happen and that's not good and healthy for screws or machine if one motor stalls racking gantry at rapid speeds.!!!!. . . . With belts running out of sync is not even in the frame and stays set just like the day it was set regardless of crashing or motor tuning.!! . . . .And trust me I've crashed hard and plenty so it's well tested. . .Lol
  1. BUILD LOG: Wobblycogs CNC Mk1
    By Wobblycogs in forum DIY Router Build Logs
    Last Post: 02-01-2013, 07:38 PM
