Page 3 of 5 FirstFirst 12345 LastLast
  1. Quote Originally Posted by dudz View Post
    Good videos too thanks Jonathon. just watched a bit of one
    Hmpf
  2. #22
    I am still getting used to my CNC/router. But I would love a lathe soon.
    What about a small CNC lathe.? If you only need small parts then they are great and not too far removed from using CNC router.
    You can pickup Old school CNC lathes cheap and convert to Mach3, I've got 2 here that came from schools and just need drives/BOB it'sjust the same has CNC router just 1 axis less and speed control for spindle. . . If you can build CNC router you can convert a Ex-school lathe.
  3. #23
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Hmpf
    Hahaha sorry irving, wasnt paying too much attention !!
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
  4. #24
    dudz's Avatar
    If I could do it for 500 quid, I would be interested Jazz. Or maybe a longer project.
  5. #25
    Lives in East Lothian, United Kingdom. Last Activity: 5 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    justremovingsomeusefulposts
  6. #26
    Completely agree Pete but Dudz's in France so he may struggle to find a Boxford over there.? I'd suggest you look out for an Ex-school or collage lathe has they tend to be cheap and suitable for new users has they are designed with learners in mind. They also have loads of tooling with them.
    You should be able to pick yourself up a reasonable ex workshop lathe for a good price. Check out Leboncoin.fr, make sure you have screw cutting ability and make sure it comes with all the appropriate change wheels etc. I have a Vernier TV 280 (pain in PITA spindle) which is a very good machine. Make sure you have a typical nose fitting as well so that you get chuck back plates etc easily not like me.
  7. #27
    dudz's Avatar
    Quote Originally Posted by Swarfing View Post
    Yep, I look on Leboncoin every day. But they seems to sell their used lathes for 100 euros per kilo ! . I will keep looking though thx
  8. #28
    Check out models made by FAM that are popular over your side of the waters as well.
  9. The Following User Says Thank You to Swarfing For This Useful Post:
  10. #29
    dudz's Avatar
  11. #30
    That would be fantastic but has the same crappy spindle nose fitment as mine which is an A1-4 (direct nose). Chucks are impossible to find at a reasonable cost. But if you can get it for the right price then you could factor that in. Good things about it is the middle bit is a scrap bin with a coolant pump under neath. You would need two VFD's to run it and that would cost you another £150ish to add. Ask him what the lowest he would take for it and mention the problem of obtaining chucks and upgrading it to run on a single supply?
  1. SOLD: Various small CNC machines - ISEL/Unimatic
    By badgerman in forum Items For Sale
    Last Post: 22-01-2020, 09:58 PM
  2. RFQ: Small sized Parts need making, small batches
    By Ptee in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 06:07 PM
  3. eBay: large amount of machines on e bay lathes mill plus other stuff
    By Dellboy in forum Items On eBay UK
    Last Post: 17-06-2012, 09:35 AM
  4. WANTED: Wanted: Small Metal Work Milling Machine
    By 07trb in forum Items Wanted
    Last Post: 04-03-2011, 06:58 PM
  5. Lathes
    By Web Goblin in forum Milling Machines, Builds & Conversions
    Last Post: 18-02-2011, 10:32 AM
